head gasket
Posted: Sat Nov 10, 2007 10:49 am
hi, i was wondering why the block has so many water ports and when you get a head gasket most of these ports are closed. what is the reason for this.
https://forum.sxoc.co.za/
The holes will only go through if there are matching holes in the top. The block is mass production sand cast, they need holes to get the sand out again...Ero_sennin wrote:would be interesting to know, any body tried poking in the extra holes onto the gasket?
Any alu head can crack, but not that easy. 1st do a whole water system presure check, the radiator places normally does this. I just use my compressor by finding a place to add some presure. As soon as it gets to around 1 bar, the rad cap vents to the bottle. Look for signs of leakage while under presure. Check all hose clamps, waterpump bearing etc. Also make sure the water return pipe from the overflow bottle does not suck air back into the system when the engine cools down.Charl wrote:If this is true, your smiley face has me concernedjohansx wrote:
The holes will only go through if there are matching holes in the top. The block is mass production sand cast, they need holes to get the sand out again..., but punching holes will obviously only work if the blocked holes actually run in to 'next' the water channel.
On a different note, a flat one, Do ca's like cracking heads? If alliminium is crackable, in that case warping. because i loose water and it starts overheating. there are no tell tail signs anywhere of leaking water, it expands into the expansion tank but doesn't vacume back. can any one sugest anything? Or do i remove the head, again
and have it presure tested etc or am i lucky and it only be the head gasket
It also takes longer to overheat if i run it without the thermostat, so I'm thinking it causes slightly more preasure in the "circuit" before the radiator causing higher preasure pushing the water out quicker.
The oil is 100% so there is no water and oil mixture
Fan is 100% I have bypassed it at the moment so i put it on as soon as i start the car too keep it cooler longerToby wrote:This is so obvious it's often overlooked - please check your fan! If it's electric make sure it's coming on. If it's viscous, check that the viscous clutch is engaging at high temperatures (not sure how you'd do this, but a pot of boiling water comes to mind).
Geuss who's joining you, someone thought my car looked edible, i found mayonnaise in it this morningDaniel wrote:Charl i have the exact same problem now![]()
I fear im doing the headgasket this weekendbut how can i be sure its that? Have pressure tested the system, found 2 leaks. fixing that has helped f'all too
Mayo, WTF. what you mean in it?Charl wrote:Geuss who's joining you, someone thought my car looked edible, i found mayonnaise in it this morningDaniel wrote:Charl i have the exact same problem now![]()
Who can preassure test and skim it for me? Please let there be some place in east rand.
Who said oil & water don't mix?Charl wrote:Geuss who's joining you, someone thought my car looked edible, i found mayonnaise in it this morningDaniel wrote:Charl i have the exact same problem now![]()
