Hello Fellow Nissan Lovers
My dipstick has broken off into the sump. I need to buy another one. Anyone have one to sell? Or maybe give me the measurements (from rubber piece at top to bottom) so that I can source one from a scrap yard?
Your help is much appreciated!
Mike
CA18DET Dip Stick wanted
Re: CA18DET Dip Stick wanted
should be able to get on from nissan
Ok thanks for the quick reply. I shall try Nissan. But if anyone knows the measurements please post Might be able to get a similar one at a scrap yard
Phoned Nissan Cape Town. R290 for a new one. Think I will settle for that. Does anyone know if I can leave the broken tip in the sump? It should have a filter before the oil gets to the oil pump? I was thinking of taking the sump off in 9000KM from now. Just recently changed the oil so I don't want to do it now
i wouldnt leave it in there maybe try drain the oil if you lucky it may come out
the oil pickup does have a strainer on it so shouldnt be sucked up
I think you right. I would rather be safe then sorry
