Page 1 of 3
Public service warning
Posted: Sun Aug 12, 2007 9:08 pm
by The Calibrator
Posted: Mon Aug 13, 2007 8:23 am
I see you have put the dump valve before the cooler, any reason why??
Posted: Mon Aug 13, 2007 8:27 am
by Ero_sennin
Gary57 wrote:I see you have put the dump valve before the cooler, any reason why??
He did the same on my car, works great as far as I can tell
Makes sense if you think about it, it is there to protect the turbo, something about back pressure or something, so closer to the turbo it should be more efficient, why dump the air after it has been cooled by the IC?
Well thats how I figure it anyway, but I think Calibrator should rather explain this tho.
Posted: Mon Aug 13, 2007 8:32 am
I just fitted my new intercooler kit and I put the dump valve before the cooler. It would be nice to hear what The Calibrator thinks as he used to fit them after the cooler.
Posted: Mon Aug 13, 2007 8:34 am
I read it best for turbo reliability (before cooler). Mine is after cooler, it dumps and you can still hear pigeons.
For response its the other way around... but that piping is so short it wouldn't matter.
Posted: Mon Aug 13, 2007 10:59 am
by The Calibrator
The theory is that you are dumping hot air not air that has been cooled. I particularly did it on the land cruiser because that is a charge cooler and I need it to be as cool as possible.
Posted: Mon Aug 13, 2007 12:54 pm
by Toby
By putting the DV before the IC, instead of dumping cooler air into the engine bay, you'd be dumping crap-hot air into the engine bay, near the turbo and air-intake area. I don't think the IC has to "work" to cool air down, so you're not loosing out by dumping air that it's cooled. Makes for a cooler engine bay, I'd think.
Posted: Mon Aug 13, 2007 1:20 pm
its not that much air, so it wouldn't really affect it...
I've done quite a bit of reading on this, the most popular reason why people install the DV on the hot pipe is S13/S14/S15 is that its easy to install there and there is space, also the hot pipe is metal instead of plastic / rubber
Then another thing guys mentioned was, for drag racing, they install it before the cooler, for circuit / track after or keep it closed.
Most manufacturers say as close to the TB as possible but before any air temp / any injection device (Think I read that from Turbosmart).
I don't think there is a right/wrong way, it works either way
Posted: Mon Aug 13, 2007 2:05 pm
Well by dumping it before the cooler you give the cooler that second to cool down with out any hot air flowing through it.
Posted: Mon Aug 13, 2007 4:11 pm
by johansx
That Cruiser is heavy... would like to see it smoking up the tyres.... trying to catch the SX
Posted: Mon Aug 13, 2007 8:45 pm
by The Calibrator
Do you think the hot air from the BOV is hotter that the air around the turbo? There is so much air flowing through the engine bay at speed its not going going to make a measureable difference.
AS for intercoolers "working" evry atom that passes through it contributes to heating it up. This was discussed some time ago and I said the same thing I am saying now" I doubt it will make any difference to a street car"
Charge coolers are a different kettle of fish there is 6l of water getting heated up and it has to be cooled again so if I can save 2deg by venting hot air I am happy to do so.
That cruiser smokes all 4 wheels into 2nd gear. Pulls from 120 past 160 and accelerating in 5th up krugersdorp hill.
It smokes Honda Vtecs, Polo TDi's and Chrysler Crossfires and I mean SMOKES.
A stock S14 may put up a show but I suspect that a stock S13 will be toast.
Like I said be warned
Posted: Mon Aug 13, 2007 9:32 pm
by johansx
The Calibrator wrote:.
So in what area do we find this toaster
Posted: Tue Aug 14, 2007 7:43 am
by jon
Wow, what a sleeper, I'd probably go home and cry if I got smoked by a land cruiser
Posted: Thu Aug 23, 2007 2:42 pm
by Ero_sennin
the_mullet wrote:This Danville Cruiser got my Mullet senses tingling..Why would you want to do that to a land cruiser? at the end of the day it's still a land cruiser, and you still have to be seen in it..
Looks like all this chop can do is throw around insults, dont you have homework to do?
