Just another S13
Just another S13
Hey peeps
Bought myself a s13 non runner about 2 months ago... Bottom end is poked so selling most of the CA18 goods off and aiming for a SR20. Chassis is straight, interior is in good condition.
Im currently stuck in the engine bay, need to still source a SR20DET and box to fit in.
How she was collected
And what was found in the motor
I started in the engine bay first as it had several scratches and brackets, holes that I wanted to change..
What I have done till now is strip, prep and paint.
Some MS Primer
First and second coat of 2k
More to follow
Some MS Primer
More to follow
"Growing old is mandatory, growing up is optional"
ex: Audi A3 1.8T 204 kw atw (sold)
ex: VW Mk1 2.0 8v (sold)
- Skippy
- 0.2 Bar Boost
- Real Name: Matthew
Re: Just another S13
Awesome
I see another s13 hiding on the left.
nice work so far!
- DriftZ
- Car: S15
Really like where this is going...
- GameBoy
- Real Name: Roscoe
Nice going... keep up the good work!
- Engine: VG
- Real Name: Tony
Good job Tiaan, what is the final spec for your car? stock sr20 turbo or all out for road/track?
Cheers Tony
Cheers Tony
Thanks Peeps
@Tony, She is going to be a all-rounder toy... Not a daily so aiming for a 3071R and around 350-400whp should suffice .
I have put a little bit of time into my gauge pod which just needs a coat of paint now. My Motor,box and management are on their way too
Pics for kicks
Thats it for now, will continue working on her when the rest of the good arrive.
Pics for kicks
- Drillergy
- Real Name: Darryl
Pretty
Update time
So far I have fitted the motor and gearbox, starter connected up... Sorted out the heater lines, Have to wire up the rest of the management, Gauge pod is installed.
What still needs to be done, bought..
Battery Relocation + Cabling
Intercooler + Boost pipes
Radiator + Pipes
Exhaust manifold
Turbo
wastegate
Oil lines
Some seals
Fuel pump and fuel return adapter for aftermarket FPR
Down pipe
Pics for kicks
Will update when there is progress
Radiator + Pipes
Exhaust manifold
Turbo
wastegate
Oil lines
Some seals
Down pipe
Pics for kicks
- Skippy
- 0.2 Bar Boost
This motor looks familiar
Great progress so far
Awesome man.
Some Updates
Busy with oil filter relocation, mounted my new intercooler and oil cooler too.
Will try do the lines this week
Need to trim the front crash bar still and mod the front bumper for better flow over the cooler, then Ill do some ducting for the oil cooler too.
- Charlvdw
Looking good.
Just a suggestion, if you do not have a thermostat for the oil cooler, get one. When I hade the vg in my sx I had basically the same size cooler in the same location and oil temp was fine till I drove in the rain the one time, oil temp dropped to 35 degrees.
Thanks CharlCharlvdw wrote:Looking good.
I will definitely look into that and see what my oil temps do..
