S14 Gearbox Main Drive and Counter Drive Gears
Posted: Tue Mar 18, 2014 9:24 am
I'm desperately looking for a main drive gear and counter drive gear for a 1996 Nissan 200SX gearbox, although it should be common to a number of different Nissan gearboxes.
The main drive gear is 66mm OD and has 22 teeth. The counter drive gear is 88.5mm OD and has 31 teeth.
These are part numbers 32200S(A) and 32200S(B) in the diagram here: https://partsouq.com/en/catalog/nissan/part/GL/S14/322.
Does anyone know where I can get these (other than Nissan)?
Or know if they common to other Nissan gearboxes, and if so, which ones?
Thanks
Thanks
