offset and width advice please.
Posted: Sat Mar 08, 2014 12:46 pm
by troopiec
Hi guys, well im going to be buying some Volk Rays replicas (i know reps are not recommended but il be cruising in these wheels and will fit stock wheels to have fun on the track etc) anyways, i need to make a special order with them so i can get the ones to best fit my S13, im going to be going 17" as its more practical on tyres on arches etc.
- What offset should i go for front and rear?
- What width should i go for front and rear?
I wont be fitting a wide body kit anytime soon and my car at the moment is just 40mm dropped while i save for coil overs, i dont mind flaring arches if i have to in future but i want the best looking setup possible with these wheels.
What do you guys recommend? ive done alot of research online but most of the guys overseas go 18" at the rear and 17" infront but they can as pricing is alot better overseas, thats outta my budget.
heres some pics of the exact wheels i will be ordering:
17" 5x114 9j (didnt ask offset) but full set was identical widt and offset
15" 4x100 8j (not sure of offset)
I was thinking 9j at rear and 8.5j infront? but i have no idea of offsets, any info would be great thanks!
Re: offset and width advice please.
Posted: Sat Mar 08, 2014 6:32 pm
by troopiec
Heres an awsome link i found with different examples of 17" widths and offsets for S13
http://www.rimtuck.com/search/thumbnail ... =17&sort=1
Posted: Sun Mar 09, 2014 3:09 am
by victor
Hi I just fit a set of 10j at the rear and 7j In frond and you need too fit a spacer at the rear so I think you must go for n set of 8, 5j at the rear.
Posted: Sun Mar 09, 2014 9:14 am
by troopiec
hey man, well thats why offset is so important. because the right offset will determine whether you need a space or not to clear the arch or inside wheel well, i see alot of guys fit 9J at rear with +12 offset and that seems to clear well, even in the front it clears if i look on those pics and settings on the rim tuck website, plus 8.5j on the rear maybe more practical its not going to give the effect i want.
Can you post some pics or your setup victor?
Posted: Mon Mar 10, 2014 7:44 am
by Daniel
Check these and see if they help. It's what I used when speccing wheels.
http://rimtuck.com/search
http://www.willtheyfit.com/
Posted: Mon Mar 10, 2014 6:53 pm
by troopiec
Thanks for the links daniel, yip ive checked those sites really helped alot, but im still not sure what to go for haha. Should i go 9J all round and +12 offset all round with no spacers? that seems quite popular on rimtuck with the volk reps i want. but really hard to decide, and i have to secure order soon as it can take 21 days to arrive and they need order before next shipment is confirmed.
Plus its alot of money to spend for me so want to make the right choice
Posted: Mon Mar 10, 2014 10:45 pm
by NIZAN-R
9j +12 is a bit mexican
9j +20 ish is perfect
also use front and rear 9 j as wheel look changes when having 8j
Posted: Fri May 02, 2014 12:45 pm
by DriftZ
NIZAN-R wrote:9j +12 is a bit mexican
+ 1
on the front 20ET is the winner anything more and you will rub against coil over and need spacers to fix. Anything more is fine if you use a thinner wheel .... like 8j. So ja.. 20ET with 9j .. with 225.40's
Rear you have a lot more room to play but id suggest getting the same specs as your fronts.. then you can rotate easier.
Posted: Fri May 02, 2014 2:10 pm
by Nissan_Fanatic
Im running 17x9j et30 all round on my S13. Had to run a 5mm spacer in the front to just make the inside gap between the wheel and shock
safe (was 3mm, now 8mm with 5mm spacer).
They fit perfectly and am very happy with my choice.
Pics speak louder than words...
Posted: Fri May 02, 2014 5:21 pm
I'm running 17" +-8j no spacers.
Not sure if offset
Posted: Fri May 02, 2014 6:10 pm
by widowmaker
Riekert wrote:I'm running
FANTASTIC DUDE!! When joburg visit?!
Posted: Fri May 02, 2014 6:11 pm
by widowmaker
sorry, ok i inhale.
also had some trouble today, had to wave people past
by widowmaker
where the hair-pull-smiley?
Posted: Fri May 02, 2014 6:17 pm
Hahahaha
Posted: Fri May 02, 2014 6:25 pm
widowmaker wrote:sorry, ok i inhale.
What happened
