Skippy's New Ride - S13 200sx
- Skippy
- 0.2 Bar Boost
- Real Name: Matthew
Re: Skippy's New Ride - S13 200sx
Thanks gents.
Next year more Kouki upgrades coming ...
![Image](http://s20.postimg.org/6ptw9elkt/sxip_simons_town.jpg)
- Nissan_Fanatic
- Real Name: Henco
Looks good bud!
After the lowness gets added it will look like a different car![Wink :wink:](./images/smilies/icon_wink.gif)
I like all cars, I just like some more than others ![Wink ;)](./images/smilies/icon_wink.gif)
'93 Nissan 200SX
Ex: '93 Nissan Sentra 160GX - SR20VE
'93 Nissan 200SX
- Skippy
- 0.2 Bar Boost
I haven't updated this thread in a while.
Few things I have done to the sx.
-Middle box removed (still running original exhaust)
-Koenic springs installed
-Retuned at JVS : 168kw 298Nm at the fly. (0.9 bar)
-I had a double din and reverse camera for a while. Since getting a new daily the sx is only driven on weekends, double din sold and sound is in the daily.
-440cc injectors has been installed
Next on the list would be coil overs or whatever Rieks sell to me
Switched phones and lost couple pictures of the progress.
![Image](http://s20.postimg.org/ufvlojjul/sxip.jpg)
![Image](http://s20.postimg.org/5nvzhb2nx/IMG_0450.jpg)
![Image](http://s20.postimg.org/mptex56wt/s2s_supa_drift_wpmc_killarney_1_rs13_200sx.jpg)
![Razz :P](./images/smilies/icon_razz.gif)
- GameBoy
- Real Name: Roscoe
Looking good bud..
Nice dude but seriously need to sort that exhaust out its very restrictive
- Skippy
- 0.2 Bar Boost
thanks gents
Still deciding to go 63mm or 76mmSonOfAnarchy ZA wrote:Nice dude but seriously need to sort that exhaust out its very restrictive
- Skippy
- 0.2 Bar Boost
mini update:
ISC coil overs installed.
![Image](http://s20.postimg.org/jt2j5o7nh/20151128_153600.jpg)
![Image](http://s20.postimg.org/z32ecv35p/IMG_0012.jpg)
- Real Name: Jacques Louwrens
Looking good!!! congratz!!
S13 200sx CA18DET
S13 200sx CA18DET
- Skippy
- 0.2 Bar Boost
Updates :
Knock sensor cleared on ECU
retuned at Zeeline performance: 164kw 325nm at the fly @0.9bar
No major updates, just enjoying the car now.![Mr. Green :mrgreen:](./images/smilies/icon_mrgreen.gif)
- GameBoy
- Real Name: Roscoe
Nicely done...
you cant measure flywheel kw unless the motor gets pulled and is put on a engine dyno if your car was on rollers its wheel kw
I want to actually speak to a dyno guy and ask how it's calculated, because when we went to a skyline dyno day to another dyno the owner claimed his dyno one of the only dyno in Cape town that measures true wheel kw and the rest are flywheel. And on the dyno I made 169kw and 303nm, t28 1 bar with full exhaust and fmic, Matthew still running t25 and standard intercooler and basically standard exhaust stil, and we've run on the road together and on the strip and my car does pull away from his so there definitely is a power difference I pulled away from him quite a bit in the past as I should due to more mods, I know dyno figures vary but can't be so close if his dyno was wheel kw?, I duno, I havnt dyno'd my car on any other dyno yet, there's aways been this debate on flywheel kw or wheel kw on dynos haha and I'm no expert on it but would like to know
![Image](https://dl.dropboxusercontent.com/u/21878969/s13%20signature.jpg)
Most dyno's convert to flywheel power since it looks more impressive - especially if you have a lekker 20% correction factor in as well. Then it is easy to make 200kW on stock injectors and turbo.....
![Image](http://i908.photobucket.com/albums/ac290/Enzio83/random/nyancat.gif)
- Skippy
- 0.2 Bar Boost
As long the motor is running optimally.
Colijn made 169kw on auto mc dyno, another ca18det made 165kw by automc and 180kw by zeeline.
There various factors to take into account, read below some differences.
http://www.speedhunters.com/2015/05/kno ... explained/
Everyone loves power figures and when it comes to dyno sheets, the bigger the better. There will always be a steady stream of keyboard warriors stroking their ego on various forums by posting up their latest dyno sheet, and next comes the inevitable battle about which dyno reads high or low, and how does that compare to ‘X’ brand of dyno. The reality is that every brand of dyno will produce a different reading.
The dyno should be considered as a comparative tool only. Personally, I don’t care if a dyno reads in killowatts, horsepower or mega-ponies. What I’m interested in is how much power I had when I started and what I ended up with when I was finished. This is the true value of a dyno from a tuner’s perspective and trying to compare numbers between different dynos is pointless. This also means when you are developing or modifying your car, you always want to do your testing on the same dyno.
