motor and gearbox fitment help
smash!!
Real Name: Ash
Post by smash!! »
Hey guys im really struggling to get my gearbox onto the motor is there any tricks I can try ? I tried to line up the clutch the best I could but it still wont go on, clutch fits the center shaft of the gbox , motor and gearbox are out the car
smash!!
Real Name: Ash
Re: motor and gearbox fitment help
Post by smash!! »
Its a ca18det
that clutch needs to be 100% aligned or it wont go otherwise use a socket to move the crank so that the spines line up aswell. is the box in or out the car?
smash!!
Real Name: Ash
Post by smash!! »
Motor and gearbox are out
ja its important that the clutch is aligned and then the splines must line up. maybe try getting a broom stick or something that will fit to align it
smash!! wrote:Hey guys im really struggling to get my gearbox onto the motor is there any tricks I can try ? I tried to line up the clutch the best I could but it still wont go on, clutch fits the center shaft of the gbox , motor and gearbox are out the car
Ran into the same problem and a budy helped me out check in the centre of your crank were the fly wheel bolts on if you have a bush inside there its a little 6mm bush as that bush aligns the gear box shaft, if the clutch it not 100% alinged it will not go in, put the gear box shaft just about in by the motor then take your prop put it on the gear box and turn in left to right till the pressure plate starts turning simultaneously with prop then you know that the splines are lined up then gear box should just slide in place, broom stick will not work if you have the bush, i hope this helps
Post by Ero_sennin »
allign it as best you can, make sure that the shaft is in the hole :shock:
Then use 2 gearbox bolts, and tighten opposite each other slowly and it will pull the two together, make sure its not skew and there should not be a lot of resistance, too much resistance, then something is not aligned... but once the splines start to align properly it will slide in easy.
Did you put a new bush in? as it might be a tighter fit to the shaft? causing a little bit of resistance.
http://seat-sport.co.za/forum/viewthrea ... d_id=10699
broom will work! granted not the best idea but if you struggle then worth a try
Yea the clutch should be properly aligned or you will have issues, get a straight broom stick as suggested or get an alignment tool, you cant just guess the allignment.
NIZAN-R
Real Name: Renier
Post by NIZAN-R »
Click here to learn how to add YouTube Videos to your phpBB forum
you need alingment look Image <universal one
Image CA/SR/RB/Z/Hardbody all same same get from midas
smash!!
Real Name: Ash
Post by smash!! »
thanks guys will try see if I can get the tool from midas if not then back to the broom stick idea
