Page 1 of 3
Wiring a Dicktator Wasted Spark up to a CA18DET For Dummies
Posted: Wed May 15, 2013 3:13 pm
Thanks to
Poizen for the diagram.
Re: Wiring a Dicktator Wasted Spark up to a CA18DET For Dumm
Posted: Wed May 15, 2013 3:39 pm
by poizen
works the same for sr20 only diff is the Cas wiring you just need to swap the wires around iirc but the rest is the same
Posted: Fri May 17, 2013 4:16 pm
Ok refurb of the drawing
Posted: Fri May 17, 2013 4:27 pm
by poizen
Nice redraw but coils and injectors must not go to batt or they will be on all the time
injectors amd coils need to be connected to batt via a relay to ignition
Posted: Fri May 17, 2013 4:33 pm
Corrected...hows that?
Posted: Fri May 17, 2013 4:38 pm
by poizen
Looks good im on my phone will look properly when I get on laptop
Posted: Fri May 17, 2013 4:42 pm
kwl thanks let me know what changes need to be made
Posted: Tue Nov 12, 2013 4:55 pm
by smash!!
Hey guys do you leave the original managment in the car or take it out?
Posted: Tue Nov 12, 2013 6:37 pm
I took mine out completely
Posted: Wed Nov 13, 2013 11:51 am
by smash!!
what features do you lose ? SonOfAnarchy ZA thanks for the reply, on the tacho cable on the dicktator where would I connect it up to ? coz surely if I remove my std ecu it will stop the rev counter working?
Posted: Wed Nov 13, 2013 12:09 pm
by Enzio
smash!! wrote:what features do you lose ?
Temperature compensation
Knock compensation
A/C control (cut-off while accelerating, idle control, etc)
Fault diagnosis for sensors
So, pretty much all the safety features of the stock ECU.
As for the rev counter, I believe you just connect the output from the ECU to a pin on the back of the cluster.
Posted: Wed Nov 13, 2013 12:31 pm
there is a plug there by the ecu that goes to the dash cluster will upload a pic later for you.
Posted: Fri Nov 15, 2013 10:03 am
by smash!!
thanks bud
Posted: Fri Nov 15, 2013 10:43 am
thats the plug you use and those 2 wire are the ones you need. one is for the tacho the other is your temp guage can remember which one is for what you will just have to measure which one went to the temp sensor
Posted: Fri Nov 29, 2013 4:14 pm
Just FYI dicktator wasted spark does not work with a stock CA18DET CAS(crank angle sensor) the trigger plate needs to be changed
