Wiring a Dicktator Wasted Spark up to a CA18DET For Dummies
Discussion of Managements and Mapping
Tobievandernest
Real Name: Tobie vd Nest
Re: Wiring a Dicktator Wasted Spark up to a CA18DET For Dumm
Post by Tobievandernest »
In this post it's mentioned that the trigger plate needs to be changed.
What trigger plate is required with the Dicktator Wasted Spark for ca18
Part number? Where can I buy one?
Om te meet is om te weet.
contact dicktator they should have wheels otherwise i know of a guy who has a dicktator wheel pm me your number
Tobievandernest
Dictator can supply the disc for R150
Tobievandernest
Do I need to use the Dicktator ignitor module or will the std Nissan one work?
stock one should work just remember that stock has 4 inputs and the dicktator has only 2 outputs so one output must go to 2 inputs i had one of those dicktator ignitors might just be best to get one to simplify life remember the stock ignitor is old
Tobievandernest
Any advice on what to do next. I can't seem to get the std nissan disc out of the CAS to replace it with the dicktator disc.
Tobievandernest
Here is a link for anyone who wants instructions on how to replace the disc in your CAS with a dicktator disc.
http://aemelectronics.com/files/instruc ... 20Disc.pdf
