Page 2 of 3
Re: Wiring a Dicktator Wasted Spark up to a CA18DET For Dumm
Posted: Fri Nov 14, 2014 12:24 am
by MOOSE248
PLEASE HELP
I have a sr20det with a dictator wasted spark management system, its wired up the same as your diagram but i only have spark on cylinder 1 and 4 when cranking. I have rotated coils and still the same thing, i have got the trigger wheel from dictator, i have tried another igniter and i have tried another ecu but still the same problem
Posted: Fri Nov 14, 2014 5:55 am
Swap the output from the igniter with 2&3 and see if the spark moves.
Posted: Fri Nov 14, 2014 6:33 am
by MOOSE248
What must the trigger plate look like for a sr20det
Posted: Fri Nov 14, 2014 6:34 am
by MOOSE248
I did and it moves to 2 and 3
Posted: Fri Nov 14, 2014 6:36 am
by MOOSE248
And i have checked continuity with the output wire from the connection to the box and its got continuity
Posted: Fri Nov 14, 2014 9:00 am
measure from the plug to number 2 and 3 and make sure that the correct cable is going there and make sure the trigger and home signal are not swapped
Posted: Fri Nov 14, 2014 8:39 pm
Post a screen shot of your main setup page.
Posted: Sat Nov 15, 2014 10:03 pm
by MOOSE248
Ok i have spark but now im battling to get the timing wright with the cas
Posted: Sun Nov 16, 2014 5:51 am
Adjust in main setup
Posted: Sun Nov 16, 2014 6:17 am
by MOOSE248
I have but still nothing
Posted: Sun Nov 16, 2014 6:18 am
by MOOSE248
I think i dont have the trigger wheel set in the wright position
Posted: Sun Nov 16, 2014 1:39 pm
The cas should be turn all the to the right then the adjustment comes on the ecu so that the crank timing matches the the timing shown by the ecu
Posted: Tue Nov 18, 2014 10:16 pm
by MOOSE248
Why would my rpm on the dicktator fluctuate while cranking
Posted: Tue Nov 18, 2014 10:28 pm
by MOOSE248
At times it would go up to 30000 rpm and other times it will be normal while cranking
Posted: Wed Nov 19, 2014 8:06 am
is 30000 a typo? you might have swapped the home and trigger signal around. make sure you have good grounding aswell
