Wiring a Dicktator Wasted Spark up to a CA18DET For Dummies
Re: Wiring a Dicktator Wasted Spark up to a CA18DET For Dumm
PLEASE HELP
I have a sr20det with a dictator wasted spark management system, its wired up the same as your diagram but i only have spark on cylinder 1 and 4 when cranking. I have rotated coils and still the same thing, i have got the trigger wheel from dictator, i have tried another igniter and i have tried another ecu but still the same problem
Swap the output from the igniter with 2&3 and see if the spark moves.
What must the trigger plate look like for a sr20det
I did and it moves to 2 and 3
And i have checked continuity with the output wire from the connection to the box and its got continuity
measure from the plug to number 2 and 3 and make sure that the correct cable is going there and make sure the trigger and home signal are not swapped
Post a screen shot of your main setup page.
Ok i have spark but now im battling to get the timing wright with the cas
Adjust in main setup
I have but still nothing
I think i dont have the trigger wheel set in the wright position
The cas should be turn all the to the right then the adjustment comes on the ecu so that the crank timing matches the the timing shown by the ecu
Why would my rpm on the dicktator fluctuate while cranking
At times it would go up to 30000 rpm and other times it will be normal while cranking
is 30000 a typo? you might have swapped the home and trigger signal around. make sure you have good grounding aswell
