Methanol injection
Posted: Mon Apr 15, 2013 9:56 am
by harleyzx1400
Hi, guys. If any of you are running methanol on your SR20 DET's, do you use 100% methanol or do you dilute it? This is only for the street. I am using an AEM kit. Thanks.
Re: Methanol injection
Posted: Mon Apr 15, 2013 9:59 am
by Grobblere
As far as i know you need to mix it 50/50 with meth and water for street, racing usage the guys gives it added amounts of meth.
Posted: Mon Apr 15, 2013 10:51 am
Grobblere wrote:As far as i know you need to mix it 50/50 with meth and water for street, racing usage the guys gives it added amounts of meth.
ja 50/50 but u can buy it pre mixed
Posted: Mon Apr 15, 2013 11:58 am
Remember the 50% mix is not 1L with 1L, you mix it according to the weight of 100% methanol to water.
on 5L the mix is: 2.211L water to 2.789L methanol
Posted: Mon Apr 15, 2013 3:30 pm
by 300sx
the whole idea behind water injection is to supress detonation, so that you can run more agressive timing or higher boost..
the fact that methanol mixed with water gives a small increase in power due to the energy value of the methanol combined with lower evaporation point of methanol, does not mean there is something to be gained from running straight methanol..
Posted: Tue Apr 16, 2013 9:54 am
by harleyzx1400
Is anyone actually running methanol? Will it harm the engine running pure methanol on the street? Anyone got personal experience, please let me know. I do not drift or race, so very seldom flat out, and then only for short distances. Believe me, upping the boost to 1.2 gives quite a couple more kilowatts, and a bunch more torque. Without meths I was running 0.8 bar boost. The difference is awesome. Just worried about the pistons having a fit and breaking. Thanks.
Posted: Tue Apr 16, 2013 10:13 am
like 300sx said water meth is not purly for power gain, the methanol is just their to up the octane but the water plays a crucial part in cooling as far as i know methanol has a boiling point of 64.7 degrees c but water is 100 degrees c thus more cooling out of water therefor you loose alot of the cooling properties if you just run methanol. you better off just throwing meth in your tank i would not go 100% methanol. at 1.2bar you will need the water to keep the charge temp down or risk serious pre detonation!
this is my understanding correct me if im wrong guys
Posted: Tue Apr 16, 2013 10:28 am
by harleyzx1400
I fitted the methanol so I could increase the boost without detonating. I have had it set up on a dyno and it seems to be ok, not that I can hear when the pistons are selfdestructing, but I do not want to have to call a tow truck in the middle of nowhere after the big bang. Just being overly cautious, as usual! I have googled it till I am blue in the face, and there seems to be differing opinions on 100% meths or water/meths. The CamaroZ28 forum is quite helpful, but also not a definite answer. I suppose I will be the test dummy on this one. Lets see what happens. Cheers.
Posted: Tue Apr 16, 2013 11:56 am
To a short answer the 50/50 mix was tried and tested to be the best, there is always a million opinions, sometimes you have top try something different to see how it works.
Just remember one thing, cars that run on pure meth(as fual) needs to run way ritcher FR's because meth and fuels combustion is way different, point is that just pure meth may not make much diffs for detonation unless you spray more of it.
Posted: Tue Apr 16, 2013 12:12 pm
by harleyzx1400
I must be running very rich, cause when I put foot, the fuel gauge drops faster than the Rand against the US Dollar! The methanol level also drops very quickly, so I think it is set quite high. I just have the methanol spraying in on high boost, above 0.8 bar, under that it does not activate. Thanks for the info. I am holding thumbs that it works out. Cheers.
Posted: Tue Apr 16, 2013 4:33 pm
on a similar topic how do you determine the nozzle size you need to use?
Posted: Wed Apr 17, 2013 9:38 am
by harleyzx1400
I got three nozzles. Each one is for a certain powerband, eg up to 180kw, up to 250kw etc. Mine was set up on a dyno, so I would presume the amount spraying in is correct. Engine is putting out 230kw and 430 nm.Goes lekka.
Posted: Wed Apr 17, 2013 10:04 am
mods? boost?
Posted: Wed Apr 17, 2013 12:13 pm
by harleyzx1400
GT 2860RS turbo, FMIC, walbro fuel pump, Dicktator,63mm exhaust, Spec clutch, Methanol, 1.2 bar boost.
Posted: Wed Apr 17, 2013 12:27 pm
nice!
