Advice noted...
Its a very smooth transition from the intake to the head ports.
I removed allot of material like you said to smooth it out .
The pic's below are still the dry runs.
But let me run with it for now as the intake has been assembled
Thanks for the input
Project Low Boost - Damn CA
Anyway got the info on the Cams.
In : 248 Degree 9.5 mm lift
Ex : 248 Degree 9.5 mm lift
Also All lifers have been reconed....
Stock on the Ca18det inlet is 7,5mm .
8,5 mm is right for the limit, But they are special lifters
