9 weeks Later and the Car is Back home on a Flat Bed from PE.
Dicktator Wiring Done
Start up Map Loaded
Water Meth Fitted
AEM Gauge Fitted
Exhaust Fitted
But still a Few Issues that needed My attention,
I fixed a Small Oil Leak (3 min job)
I Charged the Battery - R20 (Causing Start up problems)
I fitted a New Aermotive AFPR with Gauge (Previous AFPR was hooked up wrong - Causing Fuel problems on start up)
Exhaust Manifold Gasket was Blowing - Lesson Learnt - Always Skim! Even if a Manifold is new.
So I have ordered Cometic Gaskets for Manifold and Turbo.
Fetched Manifold from Engineers today - All Skimmed and Sorted.
I fitted the BC COILOVERS - Amazing! Write up to Follow!
Fitted Arms aswell. Suspension Set up is going to be Wicked!!
Fitted some Rare TENZO 18's with 265 SEMI's on the Rear, 235 SEMI's on the Front.
Also got my ACT Clutch.
Also got a Front Wilwood Kit here still.
Signage still to go on aswell.
So next week when Im back home the Manifold and clutch can go in.
And then its hit the Streets and a Dyno to fine tune.
