SX and Skyline OEM aswell as aftermarket Parts
Sparco_pro2000
Post by Sparco_pro2000 »
CUSCO Coilovers
Removed from a S13 200sx
Fits S13 180sx/200sx/240sx
A31 Cefiro
C33 Laurel
Front ones seem ok, back ones are leaking. All hight adjusters are working fine.
R6300 shiped
JIRAPORN
Post by JIRAPORN »
Can you by any chance get 18 x 9J 5/114.3 wheels with a 30 offset
.. ja now we're talking..
Sparco_pro2000
JDM NISMO 320 km/h Gauge Cluster
Removed from a 1991 GTR
Great Working order
minor scratches around odometer reset needle
EXTREMLY RARE
R3400
Sparco_pro2000
JDM Impul BNR32
300 km/h Gauge Cluster
Removed from a 1989 Skyline R32 GTR
Great Working order, EXTREMLY RARE
R3800
Sparco_pro2000
JDM DRIFT Wheel Rims
Unknown brand 1 Piece Aluminium wheels 17x7 JJ 690kg load 5x114.3 +40 offset
2x 17x7J inch Rims 5 hole @ 114,3mm
Sparco_pro2000
TEIN Coilovers
Removed about 1 year ago from a HCR32 GTST
front ones alone should fit any
R32 GTST GTR
R33 GTST GTR
R34 GTT GTR
the front shocks are fine
the back ones are leaking (defect)
all hight adjusters work fine
Even after my tests i could not find any problems but i can not garantee anything also do not offer return or refund for this item.
R6200
Sparco_pro2000
JDM Weds Wheel Rims
Removed from a 200sx S13
Weds Kreanze 3-Piece rims
4x Rims 4 hole 114,3mm
F 18 x 8J offset +38mm
R 18 x 9J offset +38mm
Fits alot JDM cars with 4x114,3mm
Ask for price
Sparco_pro2000
Bridgestone NPG Coilovers
Removed from a BNR32 GTR
Fit BNR32 GTR and HNR32 GTS-4
Coilovers Used until recently with no problems. Great working order as far as we could test them
R8700
Sparco_pro2000
JDM Mines ECU
Removed from a 1990 BNR32 GTR RB26
Fits 08/1989 to 11/1990
Ecu Nr. 23710-05U02
Mapped for :
Boost Up
Higher Rev limiter
Aftermarket Intake filter
Aftermarket Intercooler
Aftermarket Exhaust
Specs:
1 Eliminate 180km top speed limiter
2 Shift rev limiter timing
3 Eliminate boost limiter
4 Modification of fuel correction map and Ignition map
5 Change quorum (k)
6 Change lattice of the map (RPM, injection time)
7 Modify every correction points
R3750
JIRAPORN
Post by JIRAPORN »
any +30mm offset 18 " Wheels?
JIRAPORN
Post by JIRAPORN »
I am looking for the complete S14 after market tail light set
Any Decent BOV's for a good price?
Sparco_pro2000
Alot will post now
JIRAPORN
Post by JIRAPORN »
Will you post tail light pics now?
