a whatttGary57 wrote:If you were making that piece you should have made a venturi...
poizen drift spec a new begining
- poizen
- Real Name: Mical Mackay
yea i did that but what is it for i dont get it shed the light pleaseGary57 wrote:www.wikipedia.com
Just a friendly warning dude.
I did a little R&D on this venturi set-up when it was suggested a while back by a not much unliked friend.
It makes you set-up prowen to surging or boost spiking as the velocity of air increases. You will normally see bigger turbo’s have like little holes cut the housing this is to cause turbulence and control the surge.
I will get a picture garret uses another system to help control this, normally smaller turbo’s don’t do this but with a venture it is possible
[/img][/quote]
[/img][/quote]
- poizen
[/quote]Pinkfluffybunnys wrote:Just a friendly warning dude.
[/img]
always wonderd why some turbos had this thanks fluff
- poizen
well i took day off work to do the turbo upgrade here are some pics enjoy
car is to low to fit jack under so must improvise
back of old turbo it was very white and not sealing on the wastegate plust the wastegate was kinda sticky to open and closed
had to cahnge timing it moved to 20degrees but not it great it just pushing 0.5bar but ill put other actuator from old turbo that pushed 0.7 bar
