Overheating
Slide 'em Wide
0.6 Bar Boost
Post by Slide 'em Wide »
MMMM yes th 200sti filter does fit....
the flat filters are generally cheaper than the cones. So this is a good idea. Is there any clue as to, If i upgrade turbo etc will the flat one & std box still serve the purpose? ( sorry this was not clear before.) What is the difference of the power increase between the flat one to the cone?
What Id rather be dooing!
Slide 'em Wide wrote:MMMM yes th 200sti filter does fit....
i think it will!
there is huge debate surrounding this topic, and i have lots of evidence (although with other motors) that the standard airbox with standard filter yields more power than either an aftermarket flat panel filter or a cone filter!
however, other people will give evidence that contradicts mine.
for the amount of power that we are talking about, i think you should just go with what you think is best, and what best suits your situation!
Slide 'em Wide
0.6 Bar Boost
Thanx will do. So std box works, and when i upgrade the turbo i will do the necessary tests.
cool let us know, with dyno results if possible!
maybe we can almost settle the argument - almost!!!
Slide 'em Wide
0.6 Bar Boost
Will do. :wink:
