Hey there... Yes, the car is running perfect thanks..... It made more power than i thought.. between .6 and .8 bar boost it made 268kw.... and 348kw on 1.3.. rev limiter is on 7150rpm.... didnt post anything cos i'll probably get told again im a liar..... dont have the dyno chart, but if you dont believe me, check it out at docs tec..... im sure they wont mind showing you..... busy with spacers and so on for more offset on the car and have some new wheels for it to... once its all on and so on, i'll post again... also the new sticker kit and bonnet.. looking forward to getting it alldone but its going to take awhile still..... busy with a car for practice which should be drivable in the next 2 weeks or so... then i'll start to try to get that one tight as well...... lets see......
jap spec wrote:Hey there... Yes, the car is running perfect thanks..... It made more power than i thought.. between .6 and .8 bar boost it made 268kw.... and 348kw on 1.3.. rev limiter is on 7150rpm....
thats friggin awesome power hey! i'm sure PFB would be interested to find out what went into the motor as he is doing an RB vs SR comparison for his next set of mods!!! with such power at low boost levels, i'm sure he would be interested!
