Why do I get the feeling you have some sort of sarcastic comment that made you type that....Charlvdw wrote:I can only smile.
- POWDER
- Real Name: Mike
Friggin "A" Bud, thats awsome, always fun having a Bike appreciate the power of our cars, lol
N E Way, u better take a Dyno Vid and Road vid when done, we wants to check it......
- POWDER
- Real Name: Mike
Well in my view, if a Tuner can Tune a Dicktator, or any other south african supplied system, he should be able to tune the Wolf 3D. All of them are basically the same idea on running principles anyway arnt they?
Anyway, hope you come right there, totally excited for you, and swing her around when she done....
Ok...was at the dyno...had some problems...while tuning through the range the nylon pipes to the boost regulator burnt....but we did not know it....so we tune and it kept on detonating on top...after a few time adding fuel...and taking off timing...I then notest that we are maxing the boost guage
So then the process started to get new pipes in to the wastegate and reroute it so that it does not burn again...at long last...that was done and we started again...it was a bit of a mission because they did not know the wolf...so I basicly tuned while they gave intell...so we got it sorted on top...lower through the rev range she is very rough....because we could not go back and do the whole map again....they still had to do plenty cars....
O....and it is a T3 turbo....not a T3/T4...boosted 1.3 bar, had to pull the timing a bit on top, they controbute that to the wastegate waste pipe going back into exhaust...they recon by venting into atmosphere adding the timing will gain me some few horses.
The result: 307 WHP
228.9 WKW
379 NM
The result: 307 WHP
228.9 WKW
379 NM
Thanks....now it's one of 2 things...bigger compressor(T4 and comp wheel) housing or water/meth to bring the timing up...then 350 WHP is on the cards....Gary57 wrote:NICE ONE, 230rwkw is fantastic...
