Shogun, +700bhp ca18det
- shogun
Turbo Control Functions
Open or closed loop turbo pressure control via PWM valve.
Modify target turbo pressure by gear selected.
Modify target turbo pressure by vehicle speed.
Two control maps selected by switch on dashboard.
Active base PWM map for easy calibration.
Idle Control Functions
Open or closed loop idle speed control via PWM valve.
Closed loop idle target speed temperature dependant.
Fuel enrichment table calibrated versus PWM percentage.
ALS Control Functions
Full ALS ignition and fuel maps.
ALS valve control together with map switching controlled
by dash board switch.
Cam Control Functions
Open or closed loop cam advance control via PWM valve.
Static offset table to zero out electrical movement effects.
Active Cam Target Advance map, load and speed dependant.
Water Injection
When not being used to control the camshaft, cam base PWM map can be used instead for water injection, giving complete load and speed dependence.
Flexible Input/Output
Three uncommitted input tables which use 0 5 volt inputs or any input the S60 knows already, linked to fuel and advance modifiers and a PWM output.
Launch Control
Fully flexible first gear launch capability.
Extensively tunable to individual vehicles.
Full Throttle Gear Shift Cut
Shift cut capability with 1ms resolution, variable for each gear with
full switch de-bounce capability.
Voltage Compensation Tables
User configurable voltage compensation tables for injector dead time
and coil on time (dwell time).
Firmware
The ECU firmware is flash upgradeable via the serial port with a special cable and software. Current firmware and software published on http://www.dtafast.co.uk.
CAN PC Communications.
The ECU can communicate with the PC via our
USB -> CAN converter. This solves the problem
of unreliable USB -> RS232 converters.
Data Logging
Up to thirty six separate items can be logged.
Three user selectable logging frequencies.
Up to nine hours logging capability.
Graphing can be done on-line to the ECU.
Diagnostics and Test Features.
Full sensor diagnostics and fault recording.
Extensive engine run time recording at different load and speed conditions.
Ability to exercise injectors and coils without engine running for fault finding.
Water Injection
Launch Control
Firmware
Data Logging
- shogun
Have searched for a long time to find combined blinker and position lights to match the new front bumper and now I have them
From Creatix I got a very nice oil cooler for the power steering. Perfect for demanding driving on track and drifting.
- shogun
Thanks to Zef Engineering and their splendid new deal with Driftworks, the car got a massive dose of safety and an awsome upgrade with new CS2 coilovers.
A major thanks to Zef Engineering and especially to you Thomas who made this possible!
