Various stuff for sale
put your dyno where your mouth is
Give us some dyno sheets mr gt2876r
I can't wait to compare mine, it should be very similar, except for the engine rebuild and all
Going to add a walbro pump and big injectors, so might have to wait even longer
Then more waiting for plumbing; hot & cold...then more waiting..
Did I mention that I'm waiting a lot?
trust me on this one man...
the first time you drive that car with all the groceries in it, you'll INSTANTLY forget about the waiting (and i've waited since september for this)
I'm getting the .8 bar dyno sheet from the calibrator tomorrow.
It was 180kw and 312nm atw. We need to do something to the actuator to get the highboost stuff working. And i don't feel like spending any more money right now.
So just enjoying the ride / getting used to the power again
high boost problem
Pls elaborate on your high boost issue, it sounds worth hearing even if I'm only going to be boosting 0.8 or less initially. is something leaking when you push the boost up?? is it your MBC or its thingies?
Also were you planning adding 102oct to boost 1.5?? I know I should install MSN to milk you for these answers but my schedule between packing/moving/capetown is just to horrible and I actually never know when I have internet at home with ADSL acting up like a 1976 datsun 1300.
i don't have MBC - i use the EBC function on the XMS.
I actually spoke to duane on saturday, and he said he can control your boost perfectly!
So obviously my actuator (Cuz i had to buy one - the 2876 doesn't come with one) is deurmekaar.
In other words, i need to buy another actuator before i can do the high boost stuff
