The new look 4x4 SX with 18's!
kidding... looing good dude
dude! do 100mm! and get me one too! heheHighboost wrote:Phoned arround :
76mm Pipe per meter = R54.72 (mild steel)
100mm per meter = R 75.20 (mild steel)
76mm 90 degree mandarel bent = R 75 (mild steel)
100mm 90 degree mandarel bent = R 101.90 (mild steel)
Flex joints s/steel per meter (cut to size)
76 mm - R 770
101.9mm - R1060
Boxes made to spec - 76mm approx R550, 100mm approx R750 (mild steel)
So say you use 6 90's , 1 flex joint of 100mm, 3m of pipe and one box the prices would be more or less:
76mm = R 1250 material only.
100mm = R 1700 material only, then stil labour/fitting/welding.
For a R450, difference I am leaning towards 100mm........
What do you guys think?
