Page 5 of 9
Re: CA18DET Forged rebuild
Posted: Mon Nov 25, 2013 9:55 pm
by mario_200sx
With what boost are you doing break-in?
Posted: Tue Nov 26, 2013 5:47 am
Start will no boost and slowly build from, it's now at 0.55.
Posted: Tue Nov 26, 2013 6:50 am
I would do higher boost lower rpm.
Posted: Tue Nov 26, 2013 7:15 am
You need the high rpm to increase the wear on the rings, also running back against compression will help set the rings in the grooves. You must go to redline in order to wear the honing down, if not you can create a ridge.
Posted: Tue Nov 26, 2013 7:31 am
Ring that are not seated tend to turn easier at high rpm.
Posted: Tue Nov 26, 2013 7:05 pm
Just did leakdown test, results as follows after only 200km:
Cylinder 1 - 10%
Cylinder 2 - 9%
Cylinder 3 - 12%
Cylinder 4 - 11%
These results prove break in procedure worked...
Posted: Tue Nov 26, 2013 8:34 pm
Great.
Posted: Sun Dec 08, 2013 9:36 pm
Meth tank in, pump mounted.
Posted: Thu Dec 12, 2013 10:16 am
by Porkbutsntatos
so neat and clean
Posted: Tue Jan 28, 2014 7:59 am
So I ordered an eccentric throttle wheel from GKTech in Aus, was delivered in 6 days of placing order on the cheapest shipping service, brilliant.
Problem is it does not fit. The slot in the center is 90 degrees out so the cable does not fit. So I drop them a mail and after a few emails back and forth their attitude seemed to have changed and I was told the throttle body is incorrect and the wheel is correct. No where on there site does it say that the wheel would only fit certain throttle bodies...
Anyway I would not purchase anything from them again of any decent value in case my car is wrong for the part...
Here a few pics...
Posted: Tue Jan 28, 2014 8:43 am
by DriftZ
dont say i didnt warn you ...lol
Posted: Tue Jan 28, 2014 9:17 am
Yeah I know...
Posted: Tue Jan 28, 2014 9:25 am
You gonna get a longer cable made?
Posted: Tue Jan 28, 2014 3:02 pm
Put it in milling machine and machine slot correct, will check tonight if it fits.
Posted: Wed Jan 29, 2014 1:16 pm
by DriftZ
