Projekto Streeto!
- DriftZ
- Car: S15
Re: Projekto Streeto!
Ebay stuff arrived from Japan 2 x rear Tailights and a Dash cluster, check the difference between the cracked taillight and its replacement ... colour is much crisper / richer... slowly getting there
Also fitted the Megan Coil Overs last night. Kept ride hide at pretty much OEM... just a tad lower. Been setting up ride quality today... just Having a slight issue with the rear though. I like the dampening at -18 from hard .. but from -17 on there's a strange sound on compression. and the softer / more minus I go the sound gets more frequent. Then if I click back towards Hard / + it goes away To try and explain the sound id use the word Squelch, its weird but its not a knock.
So I'll have to try isolate the source of the sound, that's for this weekends playtime
ride height...
ride height...
Awesome
Laters Riekert
Laters Riekert
- DriftZ
- Car: S15
Still looking for a Manual S15 ECU. While doing the Manual conversion id like to remove the rear sub assembly to give it a once over. Also considering doing Subframe spacers same time... the ones that raise the subframe a touch towards body to aid a lowered cars geometry. Anyone know which brand is best? ( only the best for the s15 )
why dont u just put a aftermarket 1 in?
PBM or SPL. They will be solid bushes, so it is going to add quite bit of NVH and if it is made decently the brand shouldn't really matter.DriftZ wrote:Still looking for a Manual S15 ECU. While doing the Manual conversion id like to remove the rear sub assembly to give it a once over. Also considering doing Subframe spacers same time... the ones that raise the subframe a touch towards body to aid a lowered cars geometry. Anyone know which brand is best? ( only the best for the s15 )
My 2c would be to keep it OEM for now.
- DriftZ
- Car: S15
ja the main reason for changing them is to help keep the camber neutral as i lower the car. Just from the little bit that ive lowered it it's already at -2.5. my goal is to run nothing more than -1.5 on the street.
Anyway financially things 'seem to be settling a bit for me, will only know for sure in about a month .. but it looks good that im keeping the 15 - permanently. Part of the reason ive made no serious changes to the car thus far has been in case i needed to sell it quickly. Its still a long term / slow project but now im considering wide body kits, and a bit more juice for the bay
- Real Name: Renier
this is what you need if you dont want to run rose jointed stuff on the street
have a look here
its a link to buy from yahoo auctions japan
http://www.bidjdm.com/bidding/search/re ... 15+ecu&ci=
what specks are the wheels you got?
have a look here
- DriftZ
- Car: S15
NIZAN-R wrote:this is what you need if you dont want to run rose jointed stuff on the street
have a look here
YES! me like Whiteline. Though i was keen on running all GK-tech suspension on this car. .. but nismo, GK-tech or whiteline.. cant complain.
Wheels are 18x 9.5j ET25.
Thanks for that site.. looks awesome .. will fine tooth combe it tonight as im still looking for a MT ECU. I also found a great ebay store based in Japan with stupid cheap prices.. will share with you tonight. ie .. bought OEM S15 tailights.. the pair for R1500 landed!
- DriftZ
- Car: S15
THANKS! found a NA ECU on that site..
- Real Name: Renier
no problem forgot about that site but its one of a few gateways to yahoo auctions.
i want to go all nismo on my s13 as soon as my house is done i am back to colecting parts
Whaaat! Share that site! Pleasseeee
Laters Riekert
Laters Riekert
- DriftZ
- Car: S15
@Nizan-R .. that site is strange man! I selected "buy it now" price.. I got charged .. then it tells me auction is closed and that I did not meet the minimum amount.. which is cool but.. I was still charged.. wtf?! Have you bought much from this site.. you sure its cool / legit?NIZAN-R wrote:no problem forgot about that site but its one of a few gateways to yahoo auctions.
@ Riekert... Ebay boet.. heres the link for the Ebay store I got the S15 stuff from. Hope it helps
http://www.ebay.com.au/sch/sideway2013/ ... 7675.l2562
- Real Name: Renier
that is strange email them and ask they shuld not charge you if it ended and all even if you dont win.
i have not used them as yet .
they are the same company http://www.rhdjapan.com so is legit,have used rhd lots of times befor.
may be a bug in the site system
- DriftZ
- Car: S15
yhe.. well i'll give it a couple days.. then make a noise. Shot
I know i can use my AT ECU.. but id prefer to use a MT ECU... so the search continues.
