Thats the thing with those crappy ratchet type spanners, you cant fit them into anyplace where they would actually come in handyDoctor G wrote:The ratchet type spanners normally have a much larger outer "ring". Will ratchet gaurantee to ease the job or willit be a case where the outer ring is too big to get into the space in the first place?
Exhaust Manifold
- Daniel
- Real Name: Daniël
i disagree - they've been friends of mine ever since a very kind brother of mine gave me a set for my B-Day. roll on october, cant wait to see what i get next.Daniel wrote:Thats the thing with those crappy ratchet type spanners, you cant fit them into anyplace where they would actually come in handyDoctor G wrote:The ratchet type spanners normally have a much larger outer "ring". Will ratchet gaurantee to ease the job or willit be a case where the outer ring is too big to get into the space in the first place?
the size 19 ratchet spanner will definitely help with removing the banjo bolts for the water pipes, but not much else.
the bolts that hold the manifold to the head are quite easy, except for those two bastards in the middle of the bottom row! other than those two, its no big deal i reckon!
