Thanks...will have a look...but I think it's time I slap on the new manifold and turbo...Adrian wrote:My car did that once. It sounded like a tracktor them I keept on re tightning the turbo to the manifold and same shit . My problem was the studs keept comming lose so I had to tighten the studs then lock up the turbo.
I asked Charl if I can have some of his time to make the wastegate pipe of the new mani because he has the tig welder on hand...but after considering that I still have to do intercooler pipes, get the exhaust at the right place and time constraints, I decided to take it to my local exhaust place, they are sommer going to remove the current turbo and mani and fit the new turbo and mani, from there manufacture all the pipes needed.
I have a 46mm wastegate that I think will be to big and don't want to waste time if it does not work, I ordered a xcell 38mm wastegate, should be here by tomorrow, my hope is to get the car dynod by friday so that i can be ready for sundays supatrax at Zwarties....
Not that I am going on the track or skidpan....
poizen wrote:did you check the turbo if it was in good condition?
I did, all looks ok, you did aswell when you sold it to me and said it looks good to go...
Thanks, yes it sits very low, I also thought it would sit higher...also yours sit so much lower than mine did its looking nice
- poizen
- Real Name: Mical Mackay
yip felt good to me just thought you would take t turbo exchange to have a lookDraco wrote:I did, all looks ok, you did aswell when you sold it to me and said it looks good to go...poizen wrote:did you check the turbo if it was in good condition?
i see the down pipe fitted will
when will all be running
Turbo exchange is in JHB, I am in PTA....if all goes well it will run tomorrow, wanted to tune on friday on dyno but my usual is to busy....so I will have to see what I can do...poizen wrote:yip felt good to me just thought you would take t turbo exchange to have a lookDraco wrote:I did, all looks ok, you did aswell when you sold it to me and said it looks good to go...poizen wrote:did you check the turbo if it was in good condition?
- poizen
Draco wrote:Turbo exchange is in JHB, I am in PTA....if all goes well it will run tomorrow, wanted to tune on friday on dyno but my usual is to busy....so I will have to see what I can do...poizen wrote:yip felt good to me just thought you would take t turbo exchange to have a lookDraco wrote: I did, all looks ok, you did aswell when you sold it to me and said it looks good to go...
oh to me they the same area
well you shouldnt really need a hetic tune i dnt think
I am sure I am still close to the ball park but with the T3 housing I might have to adjust here and there till I can get to the professionals.poizen wrote:Draco wrote:Turbo exchange is in JHB, I am in PTA....if all goes well it will run tomorrow, wanted to tune on friday on dyno but my usual is to busy....so I will have to see what I can do...poizen wrote:yip felt good to me just thought you would take t turbo exchange to have a look
