Posted: Wed Aug 04, 2010 4:45 pm
havent tried yet, but will take videonirvash wrote:drifting with that much power must be insane
https://forum.sxoc.co.za/
welcome to take a suicide rideDriftZ wrote:Im pretty sure it'd be fun most of all.. lucky bugger
Always been keen to die smilingdialate wrote:welcome to take a suicide rideDriftZ wrote:Im pretty sure it'd be fun most of all.. lucky bugger
thanks man, its awesome!SlowMo wrote:wow that is some crazy power there dude!!! well done
nope, theres just one pump, no surge or primary pump and linked straight to tank..Lindt wrote:Where does the feed from the bosch pump come from, surge tank?
true rather invest in a surge take with tat expensive motor its the least you can doLindt wrote:you mean you're running a bosch pump above fuel level without grafity feed at least, ok, that's suicide
still have a small chance it will suck dry as most sx owners drive with the petrol light on350Z wrote:True , for that motor & money inside I would run a Internal pump feeding a small Surge Tank and 1 or 2 External pumps feeding the motor.
But then again 1 Internal HFP 255LPH Pump can feed up to 600HP !![]()
guys i hear you.. and now that you are all finished telling me how im on a suicide mission.... we are installing a surge system with the walbro that was in the car originally, this is a temp measure, just set it up like this to dyno the car.poizen wrote:still have a small chance it will suck dry as most sx owners drive with the petrol light on350Z wrote:True , for that motor & money inside I would run a Internal pump feeding a small Surge Tank and 1 or 2 External pumps feeding the motor.
surege tank is a piece of piss to make go to nearest engineerign shop i say max 3hours making it so you looking at under 1k for it then yout low pressure pump to the tank and high pressure out you will want mayb 2-3liter storage in the tank least then you never risk that chance
i mean what is 3k compared to a 50k+ motor
the 044 can pump 600 litres an hour.. its like having 2 and a half walbros.350Z wrote:True , for that motor & money inside I would run a Internal pump feeding a small Surge Tank and 1 or 2 External pumps feeding the motor.
Quoted from the bosch pump suplier site:dialate wrote:the 044 can pump 600 litres an hour.. its like having 2 and a half walbros.
