Some fine work there looking forward to seeing the car at Saldana, hopefully it will run good speeds.
O yes the "squish pads" stepping on some toes there
Happy days ahead for you when it makes the numbers
Injectors sizes?
Exhaust AR?
Cambelt ?
This going to make 1000nm I think....
there was a Rb30 in pta already 2 years ago in a S14 but it was a hackjob and still it went like stink.
Top feed 750cc injectors. Manifold can take top or side feed.
T66 turbo, T4 A/R 68 exh housing (should spool fast)
Audi cam belt
Lots of small things done on head and block, not just a quick job to build a RB30DET.
AUDI cambelt, i was looking my self mad for someting localy available to match upand you used an audi cambelt,what audi motor is that from,and price?i ended up buying a greddy belt?!?!? any other secrets you can help us out with ?
Think a Vw cambelt works also-think passat 158 tooth or something.
That turbo is going to spool at 2000rpm already I think!!
how did you do the VVt feed?
Stock cams?
Its a 152 tooth belt, wont fit RB25/6 only RB30DET with 2 x adjustable tensioner bearings.
VVT feed is modified to get oil from the internal oil gallery in the head. Will see if it works well, first time i did it like this. Has been done before.
Stock cams and throttle body for now, will see if i can reach the power i want with the stock parts. Easy to upgrade later.
