One Savage project!!! 56k unfriendly
- 200SXSilviaSavage
Yeah guys I'll let you know once it runs!
I haven't posted for ages now cause I've been doing so much work on the car...
The engine's in...
The starter turns but nothing happens!
Checked the timing and it's on TDC
Will the air regulator on the body on the exhaust side have anything to do with this? I haven't connected it yet, cause I can't remember where each of the lines go
There are 3 lines... Please can someone go check on their car and tell me where the 3 lines all go...
Thank you... Can't wait to get it started...
Any other suggestions would be greatly appreciated too...
The engine's in...
the 3 little pipes....
will this help?
Oh and remember to plug that little shiny thingy in at the filterbox in also the one thats on the top part of the filter box...
will this help?
- 200SXSilviaSavage
Here's the pics of the motor going in and the progress up till now...
My sister's fiance helped us out... He drives a shweet Conquest RSI with a 4AGZE T3/T4 turbo motor...
Engine and gearbox in at the same time...]
The ali radiator and mountings we made up ourselves for the fans...
FPR in...
Got the pipe for the dump valve cut shorter and welded in the new place today...
Progress so far...
And now we're trying to start the thing and it won't start...
This is the solenoid valve that I would like to know where the 3 pipes from it go...
FPR in...
Progress so far...
WOW!
i didnt like the orange stuff, but at least you cant see much of it. the polished bits go really well with the blue silicone bits.
only thing is that those fans need to be flush mounted dude!
that flat bar wont do! it will work but it wont be near as effective! put them against the radiator, get some long skinny bolts with nuts and massive washers! then flush mount the bitches!
- 200SXSilviaSavage
Shweet guys!!! Shots for all the comments...
I used engine enamel for all the spraying Reikert...
And I'll definately make a plan to flush those fans VC...
Thanx Rat for the 3 pipes! Now I know where they all go
Guys! I just came back from a drive around the block in it and it's amazing!
Yesterday we had no fuel because I put the fuel pressure regulator before the fuel rail and not after it, so I sorted that out...
We got the engine started and the timing reasonably okay...
Then the stooopid clutch didn't wanna engage the pressure plate fully so we serviced the slave and master cylinders with new seals and the lot, but the problem still persisted.
So today I thought of replacing the arm of the slave cylinder that presses the fork in to a longer one... So we eventually got hold of a neat adjustable one for 50 bucks and it works like a charm!
Then I went for a drive and I don't even put half throttle at about 2200 RPM and it's already showing 0.1 Bar on the boost gauge so it doesn't seem as lag is gonna be a problem at all
It sounds amazing without the exhaust on with the turbo spool and all... Even though it sounds like an Isuzu bakkie
But that'll be sorted when it goes for the down pipe this week...
Unfortunately I've got a huge oil leak
I think it's coming from the sump where the liquid gasket seal is... Might be the power steering too... Will find out tomorrow...
- 200SXSilviaSavage
Still running the motor in so haven't even boosted more than 0.1 bar, but it will be tuned for max. 0.8 bar or when the injectors reach 80% duty cycle, whichever one comes first... lol
Just took another short drive around the block and I have to say that this turbo is awesome
I just put my foot down to just before half throttle in 3rd gear and I saw it register 0.1 bar on the boost gauge at a mere 1500 RPM!!!!
We think the leak is power steering... Tomorrow it's going in for the down pipe and for the current exhaust to be connected...
- 200SXSilviaSavage
