What code are you getting?Trance101 wrote:
Oh ok, well it turned out the problem was with the user
When u first turn the screw on the ECU fully clockwise it starts flashing codes for the different modes u can choose. ie 1, 2, 3, 4 ,5 denoted by that number of flashes.
For self diagnostics you need to choose mode 3. So, after it has flashed 3 times turn the screw fully anti-clockwise.
Now, it will flash the fault codes. The number of red flashes make up the first digit of the code and the number of green flashes make up the second digit of the code.
When I first looked at mine I couldn't see the green light as it was mostly covered by the edge of the window...
Here is a good thread about it from another forum.
Reading Fault Codes
- GoldenEagle
