Page 4 of 5
Posted: Wed Aug 22, 2007 7:13 pm
by Doctor G
SR20DE RWD N/A motor - R3950
SR20DET gearbox - R2900
Forged pistons - R4.5k
Forged rods - R4k
Bearings, ARP studs, Gaskets - R5k
Bigger injedetors - R2.5k
Turbo - R12k
FMIC - R3k
Radiator - R1.5k?
EMS - R7.5k (fitted)
20v VE head - R10k (complete motor)
eish, met ys ja :?
Posted: Wed Aug 22, 2007 8:57 pm
by Sokar
Sokar wrote:The ONLY 2 factors a CA has against it is age and availability of parts.
The Calibrator wrote:Face it the CA is in the same league as ox wagons they work but we have moved on to better things.
You're falling behind again...
My main point is he HAS a CA, its in the car, its running. If you're going to go through all the effort of doing an engine swap, new wiring, new management etc etc etc, why not put in a motor that will realistically meet his goal?
The Calibrator wrote: Rb= costalot you can double the cost of the motor and then add some more if you want it done properly
I think to get an SR to that kind of power you're going to be spending close to that amount of money...
At the end of the day I'm not here to convince the dude or spoon feed him, he can do whatever the hell he likes, its his money, but he's the one that put a poll up on the subject, not me.
Posted: Wed Aug 22, 2007 9:01 pm
by Sokar
All these:
Forged rods - R4k
Turbo - R12k
FMIC - R3k
Radiator - R1.5k?
Excluding the VE Head is R46k and some change.
Thats the price of a Skyline GTS-T RB25 Front Clip landed here, in fact I think its even cheaper than that, that should include everything you need excl a custom driveshaft.... Makes you think....
Posted: Thu Aug 23, 2007 9:23 am
i know somebody who does those imports - engines, gearboxes and front clips if necessary.
a skyline R33 GTR front clip import is less than R20 000 at cost for the importers. in fact i think its closer to 14-15 thousand than 20 thousand.
so if you add profits and fees, you may be looking at getting an RB26dett front clip for less than 30 grand.
a GTS-t front clip may cost less than 20 grand!
i would definitely do that. everything is there for the swop. management, wiring, brakes, 5 lug hubs, engine and gearbox, filters, electronics, mounts, crossmembers, etc, etc!!!
Posted: Mon Aug 27, 2007 1:59 pm
by jap spec
R33 front clip - R32000
R33 motor and box - R15 - R16000
R33 motor - R11000
RB26 motor and box - R25000...they dont really break them up, RB25 box bolts straight on aswell
Posted: Mon Aug 27, 2007 2:15 pm
well there you have it folks.
straight from the horses mouth - yes japspec, i may have called you a horse, but at least i didnt call you a donkey (an ass!!!)
anyway - i reckon using a front clip to do a swap is probably the best way to do a conversion like the rb25det.
you get everything you need that way, and you may be lucky enough to get some aftermarket bits too!!!
Posted: Mon Aug 27, 2007 3:48 pm
by jap spec
I dont know so much... I got just the motor and box for 16k...im running the dictator system cos there's a guy down here who know's it well...cooler and thats it... fitting it is the expense or would be for an s13, but if you can sort that out...2k for management and it can run anything... looks its not as good as standard, but it beats going Autronic.... 18k box, motor and management....the rest is labour...and pipes.... i recon RB for any car...its seriously teh shit
Posted: Mon Aug 27, 2007 3:51 pm
i meant for the s13, the r33 front clip would be sweet.
for that cost you would get the motor and gearbox.
then you would get all the standard electronics, thats computer box and all the little peripherals, like injector resistor pack, coil amp, etc.
then you also get the stock 'cooler.
you also get the r33 front crossmember that allows to install the motor without much fabrication. sorted.
you would also get the bigger radiator from the r33.
to put the cherry on the cake, you would get the front calipers and discs, and you would be half way to doing a 5 stud hub conversion!
MHO!
Posted: Mon Aug 27, 2007 3:55 pm
by jap spec
for sure....its just that some guys dont got 32k in one go... i recon though, that if someone was keen to get one of those motors, i would be keen to take the calipers off his hads for sure....and also recon that some other guys would want some other sneaks..
Posted: Mon Aug 27, 2007 6:10 pm
by The Calibrator
Last I heard it was illegal to import front clips into RSA
Posted: Mon Aug 27, 2007 6:55 pm
by bruno_miranda26
Doctor G wrote:The article stated that a CA20 crank is forged, unlike the CA18 unit? Is it 4cw or 8cw?
Bruno how much work was it to make the RB fit? Engine mountings etc? How much power can it handle before internals etc are needed?
If you use the R25DET gear box and the crossmember is not work at all, only the aircon motor mounts have to be re-welded for the pulleys to align, but other wise it took Manny Marinho 3 weeks(including the waiting from plumbing and Exhaust system that took 6 days) if you use the CA18 X-Member you have to build your own engine mounting which is not difficult if you know what you're doing(That was done in +- 4 hours) then my RB came with the complete harness which Manny cut it off to install a Gotech-Pro.
I've heard that the engine can do up to reliable 350KW, but you need to change injectors and BB/ceramic impeller turbo cos it can not handle more than 1 bar which is a shame coz that thing spools so quick :twisted: , i've got 200KW on the RW at 0.7bar, i was told that if i had a bigger down pipe and 73mm system i could get a bit more out of it with the same 0.7bar.
Regarding to finding parts, i'll be amazed how many parts from the old RB30/RB20 fits on that engine, off course if you blow the engine might aswell get aftermarket stuff. :twisted:
Posted: Mon Aug 27, 2007 7:52 pm
by jap spec
I know that most of the RB30 parts are bolt on onto the RB25....starter motors, aircon units the lot.... Even the RB25 turbo manifold bolts onto it if i recall...all teh guys overseas go RB30DET.....the head fromt he 25 even bolts onto the 30....love them skylines
Posted: Tue Aug 28, 2007 10:12 am
thats good to know(about the parts interchangeability), but i guess its also an intuitive assumption!!!
i've driven bruno's car and words cant describe. if japspec's 'liner is similar then its gonna be awesome.
but G, its up to you man. i would love to see something different man. RB engines, UZ engines, etc. BUT, i guess the SR20 conversion is "something different" in this country cos most guys are still trying to extract CA power!!!
go with what you know!
Posted: Tue Aug 28, 2007 3:22 pm
by Doctor G
VC first of all - PUT THAT HOOCH back in your signature!! :P
Secondly, yes I also think that despite all the pro's and cons the VET still seems like a sweet option.
I can get a DET RWD bottom end (minus pistons and rods) for R1500. Some forged internals + a VET head and it's good to go. (ignoring the ovious custom work required and the millions of things that will need to be done to make it work) :wink:
The DE RWD motor is R3900.
If I go the VET route it will be a long term project.
On the plus side. The 20V VET motor costs around R10k. Now given I will only use the head, bottom intake runners, oil and water pump from this motor it may seem expensive, but I thought about it and
The Head flows A LOT more than a DET head. I
t has some wicked cams in that head from stock. So you save on flowing/porting (R2500), cam gears (R3000) and aftermarket camsR4-5000).
Posted: Tue Aug 28, 2007 6:29 pm
sounds like you have your mind made up.
you go bbbbooooooiiiii!!!!!
