SR20DET gearbox - R2900
Forged pistons - R4.5k
Forged rods - R4k
Bearings, ARP studs, Gaskets - R5k
Bigger injedetors - R2.5k
Turbo - R12k
FMIC - R3k
Radiator - R1.5k?
EMS - R7.5k (fitted)
20v VE head - R10k (complete motor)
eish, met ys ja
Sokar wrote:The ONLY 2 factors a CA has against it is age and availability of parts.
You're falling behind again...The Calibrator wrote:Face it the CA is in the same league as ox wagons they work but we have moved on to better things.
I think to get an SR to that kind of power you're going to be spending close to that amount of money...The Calibrator wrote: Rb= costalot you can double the cost of the motor and then add some more if you want it done properly
If you use the R25DET gear box and the crossmember is not work at all, only the aircon motor mounts have to be re-welded for the pulleys to align, but other wise it took Manny Marinho 3 weeks(including the waiting from plumbing and Exhaust system that took 6 days) if you use the CA18 X-Member you have to build your own engine mounting which is not difficult if you know what you're doing(That was done in +- 4 hours) then my RB came with the complete harness which Manny cut it off to install a Gotech-Pro.Doctor G wrote:The article stated that a CA20 crank is forged, unlike the CA18 unit? Is it 4cw or 8cw?
Bruno how much work was it to make the RB fit? Engine mountings etc? How much power can it handle before internals etc are needed?
