Projekto Streeto!
Re: Projekto Streeto!
that is so sexy! id trade my left nut for it lol
- DriftZ
- Car: S15
ah... unfortunately for you i have a perfectly working pair ( recently provenSonOfAnarchy ZA wrote:that is so sexy! id trade my left nut for it lol
- 0.9 Bar Boost
- Real Name: ????
HahahahahahahaDriftZ wrote:ah... unfortunately for you i have a perfectly working pair ( recently provenSonOfAnarchy ZA wrote:that is so sexy! id trade my left nut for it lol), so you need new barter material. ha ha
- smoothedgp
- Real Name: F.J Steenberg
Lol lol lol you a ledgend man!
http://www.jdmsyndicate.co.za
1992 Black Gtr32
2005 530d
1992 Black Gtr32
2005 530d
- Grobblere
- 0.6 Bar Boost
- Real Name: Eugene
Nice going there bud!!!!!
- DriftZ
- Car: S15
Thanks
Ok .. so im slowly fitting the Manual conversion parts... not the serious bits just yet obviously as I want to still use the car daily, so im starting with just the pedal assemblies etc ... but id like to wrap up the MT conversion part hunt.
Currently im outstanding the Manual SR20DE ECU... anyone know if a slightly earlier ( OEM ) S14 DE ECU will work? Because I found one on ebay ( including loom ) but they advertise the Compatibility years as ... up to 1998 only. ( remember this is the NA / DE motor .. non turbo )
- DriftZ
- Car: S15
The auto ECU keeps the car running while sitting in D / Drive and idling ( compensates with revs ) ... also i believe its got a alot less agressive tune going into gears. Plus overdrive etc.Charlvdw wrote:What's the diffs between the manual and auto ecu's?
started fitting Clutch pedal untill i found the Gearbox itself even has an ECU .. lol.. and its mounted right where the Clutch pedal is supposed to go .. ha ha
- Charlvdw
Cant you sort this with Nistune?DriftZ wrote:The auto ECU keeps the car running while sitting in D / Drive and idling ( compensates with revs ) ... also i believe its got a alot less agressive tune going into gears. Plus overdrive etc.Charlvdw wrote:What's the diffs between the manual and auto ecu's?
- DriftZ
- Car: S15
probably could... but Nistune say they dont have a listing.. but can make something up specifically.. to me that sounds $$Charlvdw wrote:Cant you sort this with Nistune?DriftZ wrote:The auto ECU keeps the car running while sitting in D / Drive and idling ( compensates with revs ) ... also i believe its got a alot less agressive tune going into gears. Plus overdrive etc.Charlvdw wrote:What's the diffs between the manual and auto ecu's?
NIZAN-R
- Real Name: Renier
the ecu thing where clutch pedal mounts controlls auto windows and stuff dont remove it.
trans ecu is some where els think above main ecu
- DriftZ
- Car: S15
ah.. ja finding little ecu boxes everywhere .. ha haNIZAN-R wrote:the ecu thing where clutch pedal mounts controlls auto windows and stuff dont remove it.
Im still trying to find the right MT ECU to replace my AT ECU.. but ive got the 'Fluffy Bunny' on the case.. so we should have answers soon
- DriftZ
- Car: S15
- DriftZ
- Car: S15
had some time to kill.. so cleaned MAF.. and made a cold air intake + heat shield. All the OEM parts are un-molested as im making a note not to do any permanent changes atleast until I know I can afford to keep the car.
The car sounds WAY better.. atleast from the engine department. Also feels like it has a bit more go in it.
Nice!
Laters Riekert
Laters Riekert
