Page 28 of 30
Posted: Wed Jun 11, 2014 7:52 am
by POWDER
D, with that little setup, if you put a microphone in the pipe and connect to a laptop, there is software you can get to isolate frequencies.... You may be onto somthing good here... That then would give visual aid to spotting det
sent from my Sony Xperia X1
Posted: Wed Jun 11, 2014 8:34 am
Hey buddy, yes...there are even how to's on doing the electronic setup, you just need to buy whatever and do it....
Posted: Thu Jul 31, 2014 8:13 am
Bought a new mani yesterday, most probably won't flow as good as the s/s import but will be a hell of a lot easier to remove and put back.
Posted: Thu Jul 31, 2014 8:20 am
nice!
Posted: Thu Jul 31, 2014 8:58 am
Its not cute, but I like the design.
Posted: Thu Jul 31, 2014 9:06 am
Thank you...maybe I'll send it for chroming...then it will be cute :)
Posted: Thu Jul 31, 2014 4:46 pm
It looks well made and nice design.
Posted: Fri Aug 01, 2014 6:59 am
It does Gary....and it will be a hell of a lot easier and faster to install and take off, the bends on the import are so close that you can hardly get an m10 nut in there and the only ones that will fit in there is the oem nissan nut that's almost as small as an m8 nut, a normal m10 nut has no chance, stud has to be shortened that results in maybe being able to tighten the nut 4 threads...that's after you struggled half an hour a piece to get it to catch.
Posted: Fri Aug 01, 2014 10:42 am
Before you chrome it....
Posted: Fri Aug 01, 2014 12:33 pm
Powercote it.
Posted: Fri Aug 01, 2014 12:47 pm
Yes...that would be the right thing to do.
Posted: Sat Aug 09, 2014 8:33 pm
Draco wrote:Bought a new mani yesterday, most probably won't flow as good as the s/s import but will be a hell of a lot easier to remove and put back.
Didn't know you get square condoms?
:P
Posted: Mon Aug 11, 2014 7:18 am
I don't understand the werds koming out of you mouf... :facepalm:
Posted: Tue Aug 12, 2014 12:30 am
Posted: Wed Aug 27, 2014 9:44 am
Draco wrote:Made myself some det cans, now I can tweak the timing and fuel a bit
Did these muffs work?
