poizen
Posts: 2994 Joined: Sat Apr 12, 2008 2:05 pm
Real Name: Mical Mackay
Post
by poizen » Wed Nov 03, 2010 3:28 pm
wow the more i strip the more i like
got oil filter off looks like never been used its spotless even the oil fiter is brand new see pics
also the coils look like never been touched
and the spark plugs are new looking to but look like specials they just say ngkR -8
what plugs should i use for this motor and what gap
and this is the turbo
poizen
Post
by poizen » Thu Nov 04, 2010 8:40 am
pics inside the tappet cover i think i looks nice no wear on the cams what you guys think
Posts: 2611 Joined: Mon May 05, 2008 7:48 pm
Post
by DriftZ » Thu Nov 04, 2010 8:48 am
looks like a virgin!
hentiebez
Posts: 430 Joined: Wed Oct 01, 2008 4:39 pm
Post
by hentiebez » Thu Nov 04, 2010 9:12 am
just one tip, you going to do it over or not, take the oil rails of cut there ends of clean them very well weld or silver solder the end back and you will be 100%. trust me i know that its like not to do it.
poizen
Post
by poizen » Thu Nov 04, 2010 9:42 am
thanks hentie ill look into it do they get full of gunk
yip i just pulled the bottom off first time its been split from the factory and no shavings and strainer super clean not even dust
the oil is black but when you put on your finget you can see its still good
id say this motor has done no less than 60k-70k kms on it just by looking at the wear which to my naked eye is none
hentiebez
Post
by hentiebez » Thu Nov 04, 2010 10:05 am
from standind for a very long time the oil tends to get sticky and those hole are not very big, just to be on the safe side. i lost a head like that.
poizen
Post
by poizen » Thu Nov 04, 2010 10:10 am
shot man yes ill need all the help i can get its a all new ball game this motor
ok im pulling them off now to have a look
Post
by DriftZ » Thu Nov 04, 2010 10:17 am
surely you could just jet thinners through them to clean out the gunk?... seems a bit extreme to cut the ends off...
hentiebez
Post
by hentiebez » Thu Nov 04, 2010 10:21 am
you can and at the same time you jet all the shit to the ends where they stay and come back to block the holes up again.
Post
by DriftZ » Thu Nov 04, 2010 10:25 am
i havent seen how small the oil end jets are.. so i cant say for sure.. but if Henti lost a head to it.. its definitly something to consider.
though your motor looks super neat.. im jealous... Hows 8k sound
poizen
Post
by poizen » Thu Nov 04, 2010 10:26 am
all tips and advice noted thanks guys keep them comming
Post
by DriftZ » Thu Nov 04, 2010 10:27 am
R8200
poizen
Post
by poizen » Thu Nov 04, 2010 10:28 am
hahaha driftz i need somthing to keep up with your beast
djtreble
Posts: 1502 Joined: Fri Jan 29, 2010 2:49 pm
Post
by djtreble » Thu Nov 04, 2010 11:27 am
That is sooo clean! Lucky!
I'd suggest replacing the oil spray bars with new ones to eliminate any chance of missing any of the gunk in them. They aren't too expensive either and are deffinately worthwhile if they save you having to replace the head.
RB25SX
Posts: 1423 Joined: Tue May 06, 2008 4:38 pm
Post
by RB25SX » Thu Nov 04, 2010 11:36 am
hentiebez wrote: from standind for a very long time the oil tends to get sticky and those hole are not very big, just to be on the safe side. i lost a head like that.
True, but if u want to make sure, just swing the motor (no plugs) without tappet cover, untill u have oil presure. Make sure all the holes spray oil on the cams.
Very nice clean engine, don think u will have a problem
R32 GTR
