its gonna take a long time methinksVlade wrote:it runs at 10rpm
Project D - 1 DEC 2007
- Vlade
- * - Club Pimp - *
- Real Name: Barend
It was a late night last night...
here some updates
Measured my bearing clearance with FlexiGuage you can get these at Alert Spares in PTA about R5.50
Next was the pistons, piston to wall clearance was also double checked... running at about 80 microns
In went the pistons
Then the squirter's
The rest followed rather quickly and I forgot to take pics
This is where I am now...
Now off to go do the head and rest...
here some updates
In went the pistons
Then the squirter's
Looking Good Man ...
Mega MG gasket set...
I have about 3 half kits in the garage, Also was the blocked decked and the head skimmed ?
- Vlade
- * - Club Pimp - *
- Real Name: Barend
Phinx wrote: I have about 3 half kits in the garage, Also was the blocked decked and the head skimmed ?
Good News is engine is in, and I've done about 10Km now, but my Wolf 3D is giving me hassles, having a real hard time starting the car, it keeps on flooding or something, It started briefly this morning, wanted to go for a drive but it died in my driveway after that it wanted nothing.
Will post pics tomorrow.
- Vlade
- * - Club Pimp - *
- Real Name: Barend
Ok here follows my update...
Been damn busy on Saturday and Sunday working on cars, hopefully this week will be without any car issues want to catch up on my gaming, movies and series
Ok getting the head on was no easy task, like I'm use to, first off I run into the following problem...
This is what happens if your head and block has been skimmed to many times.... so I fixed it by grinding a bit of the waterpump
Block all ready and prepped...
ARP Bolts, its my first experience with this stuff, its not as easy as dropping in bolts and the head... you have to hand tighten the bolts first, then insert the washers into there location in the head, you can't add the washers once the head is in there is no space for the washers to go past the bolts... then you drop the head in, and if you are lucky not to get lube on the face of your head you can start the tightening process... was scary as shit, I've never torqued bolts with lube on them, it constantly felt like the shit was going to snap any moment, because it torques so easy... Normally it bites when dry, this just goes and goes and goes till you hear the "CLICK" of the torque wrench.
Cosmetic gasket and ARP bolts
Engine all done
Motor ready to be dropped in...
I found it a bit harder dropping the motor in with the exhaust attached like that, my exhaust touched the ground long before the gearbox did... But at least it saved me that effort of trying to tighten the thing by the turbo...
I did about 10km with the car on Saturday night, had problems starting it after that, no clue what it can be at this stage it nearly does feel like the car is flooding but when I pull plugs they are dry dry dry, but the backfires indicated to me that there is unburned fuel in the exhaust...
I also installed my LS05 Lamba sensor (thanks Gary for info) works a charm at least I can keep an eye on my AFR, the car was about 10% richer than it needed to be, so I played with that adjusted it down...
I want to say thank to my buddy Danie in his absence for all his help, I didn't even ask, he just pitched up out of his own will and helped... Thanks man I owe you!
Engine all done
- Vlade
- * - Club Pimp - *
- Real Name: Barend
Got the bitch started... was a combination of things... Fuel and fuel pump relay not kicking in or so it seams, but it does start much better now, thanks Gary for the settings 30Km on the clock, gonna take it slower than last time, want to sort out the map first before I put on huge KM's...
