Page 26 of 87
Posted: Tue Apr 21, 2009 10:16 am
Kinda... I took the BOV off and just blocked the pipe like you mentioned... then took it for a spin. not bad. it actually went! boosted and everything...
it does however have a bit of a stutter when you floor it... so just tuning?? but ja otherwise it goes!!
WHOOHOO!!!!
Posted: Tue Apr 21, 2009 10:41 am
by Highboost
Riekert , did it work ????
Posted: Tue Apr 21, 2009 10:42 am
by Highboost
sorry did'nt see your post !!
Posted: Tue Apr 21, 2009 11:18 am
Highboost wrote:sorry did'nt see your post !!
hehe... yeah... bov is in pieces on my desk though... cameras batteries were dead so no pics last nite.
gonna try the washer manoeuvre today...
Posted: Tue Apr 21, 2009 11:23 am
by Highboost
Good, let me know !!!
Maybe we should design/make our own BOV....
Posted: Tue Apr 21, 2009 11:33 am
Highboost wrote:Good, let me know !!!
mmm.... sounds interesting.
Will do man!
Posted: Tue Apr 21, 2009 1:44 pm
what I was trying to say is if your dump valve had a allen key bolt like this, you tighten it and more vacuum is needed to open it on idle.
If your dump valve looked like this....it was not nessesary to open it....
Posted: Tue Apr 21, 2009 1:50 pm
aha... ok cool... yeah mine doesn't have that... this is how mine looks:
Posted: Tue Apr 21, 2009 1:56 pm
Draco wrote:what I was trying to say is if your dump valve had a allen key bolt like this, you tighten it and more vacuum is needed to open it on idle.
my looks nearly like that, not that loud
Posted: Tue Apr 21, 2009 1:59 pm
It depends how you set it....try different settings on the bolt....mine is quite loud....with my windows closed I hear it easely over the engine noise.
Mine is not set that stif(bolt not turned in too much, just enough so that the vacuum can not open it on idle).
Posted: Tue Apr 21, 2009 2:04 pm
rat wrote:Draco wrote:what I was trying to say is if your dump valve had a allen key bolt like this, you tighten it and more vacuum is needed to open it on idle.
so you have one of those and one like mine? sold my old one to Trance...
Posted: Tue Apr 21, 2009 2:16 pm
didnt buy the ssq
Posted: Tue Apr 21, 2009 2:17 pm
rat wrote:didnt buy the ssq
oh...
Posted: Tue Apr 21, 2009 9:13 pm
Posted: Wed Apr 22, 2009 10:20 am
by Highboost
Just be careful with streching, it will over time return to the original position. You streched in one direction, but when you replace it it's under constant pressure in the oppisite direction, which will make it go back to where it was over time.
Try putting something between the spring and the silver cover. those big washers, that look like shims will work.
Also make sure where the VALVE seat it does so properly all around a leak there can also cause this.
The vacuum pipe you used does not have a one way valve in it somewhere??? Cause remeber in boost there is also positive pressure on the dump valve forcing it to stay closed. Now if there is only vacuum the pressure in your intake will force the dumpvalve open if there is not positive (boost) pressure on the other side too. It uses 0.5-0.8 bar vacuum to open, so if no pressure - 0.8bar boost will also push it open for sure unless you have boost presure from the other side.
Secondly does the vacuum pipe you use not leak under positive pressure? Vacuum sucks the pipe the the fittings, boost tries to push it off..... I always used cable ties around my vacuum pipes to ensure the seal.
