So stuck on the problem I phoned them asked them if they can grind the rings, they said they have never done that, nor do they own a ring grinder... Phoned around all the tool shops no-one knew or had a ring grinder in stock...
Then I followed WidowMaker's advice and DIY'd it...
I must say it worked like a bomb! Left a very smooth finish!
Some Tips, if you ever have to do this, be very carefull with the 2nd ring, that thing is blerry soft, The first 2nd ring I grinded I only touched it a little and went to measure and it was on spec! By Luck!
Top ring is a bitch, they are damn hard and on average I took 3/5 tries to get them on spec
Oil rings required a min of 0.15" gap some was already on the min some was below
Didn't really have time to assemble much last night, only waterpump
PS: Also had a visit from KimiG and his dad, very nice guys![/img]
PSS: If you need some info on ring grinding... http://www.teglerizer.com/triumphstuff/75w_newrings.htm
