veecee wrote:
rat wrote:i see you still got the stripe
mowahahahaha! :lol: :lol:
Nice spot there Mr Ratman.... :wink:
Its not coming off anytime soon 8) 8)
@highboost - Thanx man will look into that. would be nice to get all the shiny bits shiny again. :lol:
So fitted the exhuast last hite when I got home from work... sounds nice.
idling is good ish... sounds like it has a misfire sometimes though...
This morning I got up and started searching for that rattle.
And I found it!! its the damn bracket holding on the alternator... it didn't have a bolt in... so every time the engine vibrates on a certain pitch... it starts to rattle... fixed it and then I heard the second problem... My BOV is leaking... it doesn't close properly??
I connected it to the vacuum hose like every one said but for some reason the BOV doesn't close in vacuum. You rev the car. (not even in boost) it dumps and then doesn't close.
Any Ideas?
sticky shafts are the worst!
veecee wrote:sticky shafts are the worst!
yes +1
mmm.... fix?
strip the bov, and find out why its sticky, and sort it out, or get yourself a new one???
veecee wrote:strip the bov, and find out why its sticky, and sort it out, or get yourself a new one???
well thats the thing. Its a brand new one I got from Hanco
check theres no leaks in the vacuum hose
that might be it... the thing is its like its sucking the BOV open the whole time. Like there is too much vacuum??
set it harder?
veecee wrote:set it harder?
So I'll need to adjust the spring then? cause it doesn't have a setting on it...
Yes, set the screw, tighten it, it forces the spring down on the shaft making it harder for the vacuum to open it, also oil the shaft now and then...just moisten it with thin oil.
poizen
Real Name: Mical Mackay
Post by poizen »
i heard the fake hks dump can cause alot of hassels not sure the quality of the one you got but read they jam etc
Draco wrote:Yes, set the screw, tighten it, it forces the spring down on the shaft making it harder for the vacuum to open it, also oil the shaft now and then...just moisten it with thin oil.
mmm... will take it apart and post pics.
I didn't see that it had a screw like that... so not sure how to adjust it.
poizen wrote:i heard the fake hks dump can cause alot of hassels not sure the quality of the one you got but read they jam etc
Ja, I've also heard that....
Highboost
Post by Highboost »
Not all dumpvalves are adjustable.... (with screw)
But all Dumpvalves can be adjusted :lol:
Step 1 : unscrew dumpvalve
Step 2 : Remove spring
Step 3 : Insert washer, big enough so spring sits on top of washer.(piston side )
Step 4 : Replace Spring
Step 5 : Screw back together.
Repeat till required tension is reached.
