FrankenZteins back!
- DriftZ
- Car: S15
Bits in the SR already
Exedy 6 puk clutch
3kg lightened fly wheel
Huge FMIC
Blow off V
Greddy Boost Controller
Go-Tech Pro – Crank triggered
Aries Pistons
Short Screamer
Side exit exhaust, one medium silencer 72 (considering changing to a full / rear exit system)
Walbro HC pump
DW 750 injectors
Constant pressure / quick trigger WM system ( to be removed )
AC pump, In car heater system ie.. ‘parasitic pulleys’ … removed
Oil breather upgrade
Parts I've acquired so far for the rebuild …
Devils Own Progressive Programmable WM kit
SR20 Cometic seal kit ( Includes head gasket )
B.Crower 272 cams
B.Crower Springs retainers
Greddy rocker stoppers
Eagle Rods
ARP rod bolts
Greddy intake manifold (knock off v)
Greddy fuel rail
Parts still to get.. and do ( advice / input welcome )
ARP head Bolts
Water and oil pumps ( maybe )
Rings ( maybe )
Uprated Fuel pressure regulator
SR20 Gearbox or bigger
Flipping my intercooler to make my piping situation shorter
Building a air box for the Air filter .. to be fed cold air
the right Turbo for all this ..
and the right Technician to piece it all together.. any ideas where to send it, ..someone that’s built some strong reliable SR’s ..???
Exedy 6 puk clutch
Huge FMIC
Blow off V
Aries Pistons
Short Screamer
Walbro HC pump
DW 750 injectors
B.Crower 272 cams
Eagle Rods
ARP rod bolts
Greddy fuel rail
ARP head Bolts
Rings ( maybe )
You head head studs...Parts still to get.. and do ( advice / input welcome )
ARP head Bolts
Rings ( maybe )
Change the pumps, dont be scroodge.
Yes you need rings for definate, if not new pistons or a new block and rings...
You dont need a fuel pressure regulator
Most of the flow is in the bottom half of a cooler, make those cheese holes bigger...
Guy
That brazing job looks neat. Its a bit difficult to see but did they re-attach the fender lip that they cut off or is it just smooth around the edge now? It looks like the lip is there in the last photo but its hard to tell.
To give you some confidence about brazing or braze welding (brazing uses a thin film between two largeish close areas, braze welding makes a fillet bead like a normal weld.) All original Lotus Seven tube frame chassis are braze welded, and not fusion welded. The bonus is for repair its possible to dissassemble a brazed joint unlike a weld.
There is even a process now known as mig brazing, that uses a mig welder but a filler wire that melts at a low temperature and does not melt the parent material.
- DriftZ
- Car: S15
niether do i, im just going on hear say. It seems there are many mixed opinions on this topic.rat wrote:dont know?DriftZ wrote:.. ive been told they are super fragile?rat wrote:gt30 turbo
Anyone know about the Bulls Eye turbos?
Shot Guy, ja the PBeater's cut inside and outside lip to match and then joined / shut it with some thin flat bar, .. looks like a lip, bloody good job i must say. They're spraying the roof today
