just waiting on my new spacers before i can start shredding tires but there will defiantly be videos in the near futureDaniel wrote:Need videos!
Project ANARCHY
Re: Project ANARCHY
Re: Project ANARCHY
So now with the car been registered and legal on the road though id go celebrate so took the car to the rock to play abit. Its alot harder than it looks
but heres a vid of my best attempt. i only had 5 runs at it then i burst a water line and car overheated
lucky i saw it happening and was able to get off the track before anything got damaged
http://www.youtube.com/watch?v=5SgG5bOH ... e=youtu.be
Re: Project ANARCHY
Ok so after having a issue with a water pipe i decided to replace the water lines
much to much disgust this is what I found....
So I made up a few new lines
Re: Project ANARCHY
looks like drifting! ![200SX_rockon [smilie=200sx_rockon.gif]](./images/smilies/200SX_rockon.gif)
how did you get back home?
Re: Project ANARCHY
pipe only leaked when that car was hot so i crawled home lol
Re: Project ANARCHY
So car made it to drag wars unfortunately the exhaust leak seemed to be getting worse so the car was only able to achieve 0.8bar boost but I still made do with what I had. Every run down the strip I was reducing my time nicely till they pulled me off the line for a oil leak, which I was pissed off about but quickly changed that attitude when I inspected this apparent oil leak, turns out the engine mount had broken and punchers a hole into my oil filter I had virtually no oil in my car and would have completely buggered up everything if they had let me run so unfortunately the car had to be brought home on a tailor but motor seemed fine will have to replace the filter and oil just to double check but now that its standing again I've decided to do a few upgrades and fix small issues that were long over due.
Re: Project ANARCHY
Ok so now that the car is standing its time for more upgrades lol ive made a list of all the issues i wanted to fix so the list is as follows
1. Full poly bush kit.
2. shime the diff to lock at around 60% load.
3. subframe c collars.
4. rebuild exhaust.
5. new exhaust mani gasket.
6. weld the cracks in the exhaust mani.
7. new heat wrap.
8. msd coil packs.
9. remove dash to fix anoying rattle.
10. find and fix rear rattle.
11. Rewire Spitronics for sequential fueling.
12. Engine flush new oil and filter.
13. reinforce engine mounts.
14. Big brake upgrade front and rear.
15. Big radiator
16. retune on higher boost!!
4. rebuild exhaust.
7. new heat wrap.
8. msd coil packs.
15. Big radiator
- VeNoMiZeR
- 0.2 Bar Boost
Re: Project ANARCHY
poly suspension and subframe collars = More rattles
Current: 93 Pulsar SSS N14 Japspec (in Progress)
Ex:Nissan 300zx z32
Nissan S13 200sx SR20det
Nissan Sentra 200sti Neo Vvl
Nissan 200zr RB25det
Nissan 300zx z31 Vg30et
Ex:Nissan 300zx z32
Re: Project ANARCHY
haha that is true, must hear all the new rattles i got with my poly engine mounts
Re: Project ANARCHY
Ok so it starts....
Test fit the new Radiator
Pulled the exhaust, I'm going to remove that center box.
Pulled the intake off and found a leak.
While the intake is off I though I would give everything a good clean up!
And finally I picked up my new bigger brakes for the front and rear.
Re: Project ANARCHY
Cute Jason!!
Re: Project ANARCHY
If you take that centre box out it is going to be loud as fuck.
Ask me how I know.....
Re: Project ANARCHY
Lol its not my daily so loud is good. I assume u only did 1 box?
Re: Project ANARCHY
Is my car loud Jason?
Re: Project ANARCHY
Your car sounds nice
