Re: sr20 strip down and build up UPDATED
Posted: Tue Mar 26, 2013 7:14 am
OK, then for function, you have 2 lines coming from the break cylinder, one for front F and one for rear R. The line from F needs to be T-pieced to the 2 lines the come out the ABS pump marked FR + FL. The one marked R needs to then be straight linked to the line R from the ABS pump. Then your done.... You will need propper fittings though.... Will see if I have a Pic for you.... PM me ur email address and BBM pin
