PFB's - 1997 200GSI (New Spec)
Re: PFB's - 1997 200GSI (New Spec)
like the vet plan
Pinkfluffybunnys
Real Name: Ashley
Post by Pinkfluffybunnys »
Little off topic.
But to anyone who’s Dad\Uncle did service in the armed forces you should recognise the below gun … This is the Airsoft version
Now back to the car, I’m going to put my neck on the line and say the Aviner W10\W11 Manifold flows better if not the same as the GTI-R manifold.
Yes the GTI-R manifold will allow you to fit a larger frame turbo but the W10\W100 is a new design with a better internal flow then the GTI-R and less castings protruding into the exhaust flow
GTI-R at the Top, W10 at the bottom
You can see the slightly turn flange on the GTI-R manifold
Pinkfluffybunnys
Real Name: Ashley
Well guys, I tried the old mechanic trick to clean the gunk from the head.
Didn't work to well
Before:
After:
Also I forgot VE Chain guides dont work on DE's without the correct bolts so my new guides wont fit
Here is a compare of the VE oil pump drive Vs the DE
VE oil pump pick up Vs the DE
GTI-R Pick-up doesn't even come close to fitting, So I will pull the VE pick-up off the other motor.
Well the motor is almost complete.
I need to still port the intake, The Turbo housing, Down-pipe.
Pinkfluffybunnys
Real Name: Ashley
Removal
DE Cam Removal
Pulleys Swapped over
Clutch Install
Intercooler test fitting
Turbo Fitting , Need the heat shields
New Motor In
Almost Complete
First Start-up, Bad oil leak from the turbo oil feed line
To do List:
Fix Oil leak
Fit Boost controller
Do Exhaust
Fit Wide band
Tune
Pinkfluffybunnys
Real Name: Ashley
OK we picked up a few issues this morning, The water pump failed and needed to be replaced.
The Stock SR20DET cams wont come out , We are unable to loosen the CAM sprocket bolts, So we are going to engine flush the motor till enough gunk is removed to do this.
Oil cooler plate doesn't fit so no oil cooler aswell
We got the oil leak issue sorted, Car fired up first time.
3 Inch Exhaust being fitted
Boost Controller and wide band, Yes I know shitty place for the wideband
Almost complete
First bottle of engine flush, one more to go and 20 liters of oil :)
Tunning will start tommorow
Pinkfluffybunnys
Real Name: Ashley
Testing out the sticker on the back window, Think I will remove them.
Fixed the air fuel ratio gauge
Swap completed
Still haven't switched on the boost controller.
Turbo is spooled at 3700 RPM, Cams come in at 4500 RPM, no traction from that point in first of second.
I can hear the turbo spooling down for 15 seconds after shutdown
Still got allot of tuning to do
Pinkfluffybunnys
Real Name: Ashley
Cams Have been Installed.
The fuel pressure regulator was replaced because it was knocked in causing weird issues with fuel pressure.
The boost controller was set to open the waste-gate at 0.7bar, Highest boost has been 0.8 bar.
I need to create a CAI for the car , Heat soak is crazy
I have to say thank you to my buddy. Brenwin (Sokar) who help me with the swap from day one, Thanks for all the effort.
Pinkfluffybunnys
Real Name: Ashley
Pinkfluffybunnys
Real Name: Ashley
Spec List of the build:
GT28R \ GT2860RS Hybrid turbo :)
Nismo 550cc Injectors
300ZX MAF (75mm)
63mm Downpipe - 76mm Exhaust
JWT S4 Cams
BMC DIA Intake
NISTune
F1 Stage 3 Clutch
Lightweight Flywheel
GSpec Pulleys
VE Oil Pump
63mm Piping
Ground Kit
Alu Rad
With I could fit the oil cooler , but ther is no way it would clear , Temps are reaching the 97 C range and not very happy about that.
Dude! This is a awesome car! Very nice!
Laters Riekert
wicked dude love to take a spin in it
Pinkfluffybunnys
Real Name: Ashley
Update:
Clearance with Intercooler Piping
Pinkfluffybunnys
Real Name: Ashley
Dyno Results:
268Hp (199Kw) @ 6300 rpm,330nm @ 5300rpm - Wheel Power.
Pinkfluffybunnys wrote:Dyno Results:
Lekker Power.
really? you cant squeeze 1 more KW haha nice dude
