Mr Reaper - ** Senshi**
poizen
Real Name: Mical Mackay
Re: Mr Reaper
Post by poizen »
why what you done now
they suggest the line be no longer than 100cm else you get delays?flutters etc
Re: Mr Reaper
This is how I connected mine...as I say...I am getting fluttering on very light throttle into boost but not boosting as such....
poizen
Re: Mr Reaper
Post by poizen »
huge no no buddy
with a manual you need to leave top open you are fighting forces there
just connect the manual at the bottom see pic
Re: Mr Reaper
Ok....will try that....I was just scared of the 0.8 bar spring not able to keep the boost at bay...
P3g4sus
Club Drifter
Car: Supra
Engine: 2JZ
Real Name: B.G. Smit
Re: Mr Reaper
Post by P3g4sus »
yoh, oky, so it was not rightly done then.... Will need to get the lines done properly then!
poizen
Re: Mr Reaper
Post by poizen »
why what you do
Re: Mr Reaper
According to the internet the way I did it is right...but some also say they did it your way Mical...if I boost with half or full pedal I have no probs....but just light throttle into boost trying to control it not to boost further...then it flutters...
P3g4sus
Club Drifter
Car: Supra
Engine: 2JZ
Re: Mr Reaper
Post by P3g4sus »
Closed "Circuit" between the waste gate and Boost controller, What does the top one do normally?
unless I have my nots in a twist, and the top one goes to the dicktator?
poizen
Re: Mr Reaper
Post by poizen »
if you have a manual boost controller you have to leave the top one off
when you got a electronic boost controller you use the top one the controller will apply set pressure from its own pump to keep the gate closed until you reach the set boost
the way you got it Draco will work but its still fighting forces at the same time
Re: Mr Reaper
I understand....thats the point though is it not....the electronic one does the same thing...only electronicly....but in anyway....if it works fine with only bottom port then thats ok for me...I will test it and see how it works...
P3g4sus
Club Drifter
Car: Supra
Engine: 2JZ
Re: Mr Reaper
Post by P3g4sus »
Waste gate back in, gonna test now! :D
Re: Mr Reaper
With only bottom port connected I presume??
P3g4sus
Club Drifter
Car: Supra
Engine: 2JZ
Re: Mr Reaper
Post by P3g4sus »
Right, so I will have to test first, but sounds like Bearings got fukced :facepalm:
Re: Mr Reaper
Ag no...what now????
poizen
Re: Mr Reaper
Post by poizen »
i think you must stop touching the car
