S14 Stuck
- SilviaS13
- Club Drifter
- Engine: 2JZ
- Real Name: Ernest Simpson
Re: S14 Stuck
I am going to ask a stupid question now, how do you know it is the fuel pump? seeing that you are slightly un educated about the current subject? Sorry if i am being straight to the point
- Daniel
- Real Name: Daniël
Re: S14 Stuck
Its super easy, really.
You may want to get a new seal for the tank though. I decided to risk using the old one on my S13 and luckily it works perfectly.
Wondering the same thing as SilviaS13 though
- shiraazz
Re: S14 Stuck
I drove the car to the mechanic (it didnt want to start after that) he checked it and there is no fuel pressureSilviaS13 wrote:I am going to ask a stupid question now, how do you know it is the fuel pump? seeing that you are slightly un educated about the current subject? Sorry if i am being straight to the point
Driving is not my hobby, it keeps me sane
___________________________________________
Current : 1996 S14 200SX
Will be back : 1999 E39 540i
RIP : 1994 E36 325i
Ex : 2001 Daihatsu Coure 1.0
Ex : 1993 Jetta II
RIP : 1994 E36 325i
Ex : 1993 Jetta II
- Daniel
- Real Name: Daniël
Re: S14 Stuck
What happens when you connect 12v directly to the fuel pump? Is the pump dead or is the fault somewhere else?
I had a problem once where the 'trigger' wire from the ecu to the fuel pump relay had a break in it, leading to the fuel pump not getting any power.
Just trying to possibly save you some money, you may not need to replace the pump. Ofcourse replacing the tired old one with a new one is never a bad thing.
- shiraazz
Re: S14 Stuck
The mechanic was busy with other cars at the time, he did a quick check, he will only do it tomorrow, and i did think maybe there is a relay contact issue, but its hard to convince someone that thinks they are smart, that there could be another cause
RIP : 1994 E36 325i
Ex : 1993 Jetta II
RIP : 1994 E36 325i
Ex : 1993 Jetta II
- shiraazz
Re: S14 Stuck
There is fuel, over 1/4 tank, i never changed it since i got it in feb
RIP : 1994 E36 325i
Ex : 1993 Jetta II
RIP : 1994 E36 325i
Ex : 1993 Jetta II
Re: S14 Stuck
Its pretty common for the standard pumps to fail at a point, walbro is awesome, fit and forget.
I put a walbro in every single one of my 200's as a first job and never once had problems.
- shiraazz
Re: S14 Stuck
That bloody MF of a mechanic, didnt even take out the pump yet. Now im at work, (dont ask how i got here) dont know how im getting back.
![200SX_2guns [smilie=200sx_2guns.gif]](./images/smilies/200SX_2guns.gif)
RIP : 1994 E36 325i
Ex : 1993 Jetta II
RIP : 1994 E36 325i
Ex : 1993 Jetta II
CC Motorsport
- Real Name: Geoff
Re: S14 Stuck
i would check fuel filter as well but if you cant here the pump then i wont argue with your doctor
fast is just not FAST enough
- shiraazz
Re: S14 Stuck
The best way to do it, is to do it yourself I guess. Lesson learnt
RIP : 1994 E36 325i
Ex : 1993 Jetta II
RIP : 1994 E36 325i
Ex : 1993 Jetta II
- shiraazz
Re: S14 Stuck
Ok, car is sorted, pump power was shorting out (pump is fine), my dad went and fixed it, i will go to turbo toys for the walbro pump
RIP : 1994 E36 325i
Ex : 1993 Jetta II
RIP : 1994 E36 325i
Ex : 1993 Jetta II
