Good luck dude!
Bigger turbo means lean mixture?
I was running 1 bar boost according to wolf, according to guage a bit more.
With the new turbo I am not taking it so far...the boost pics up and will boost to and over 1 bar if I keep giving throttle....but the black smoke starts just before boost if you give throttle and gets worse the more you give throttle.
I have not tried to drive it hard because I know the feulling is off...
Yes this will cause your car to smoke on a hot day if it was tunes on a cold one, this is why you should have a IAT sensor if you are running MAP.What you are proposing would be the diffirence between a cold and hot day, does ur car smoke on a hot day or cold day?
Simple formular of PV=mRT, use this and see what the difference in mass of air per 5 degrees of air temp...
This is because the standard map uses MAF which measures the mass of air, not the pressure.I'm not going to get into any arguments but 0.5 bar is still 0.5 bar, this is the reason you can run a T28 at the same boost as a T25 on a standard map without problems. But what's the point of that?
0.5 bar is a pressure reading isn't it? So the MAP would see the 0.5 bar on both turbo's
The MAF measures the air before the turbo anyway so wouldn't the turbo be sucking in the same mass of air to build up 0.5 bar pressure in a system of the same size despite whatever turbo is on there?
Basically the air mass and air pressure would be the same at 0.5 bar no matter what turbo you use? Or am I totally wrong?
- aep886
- Real Name: Davey
different turbo measure different at 0.5bar... coz the size different... both MAF and MAP are measure before entering the Turbinedjtreble wrote:0.5 bar is a pressure reading isn't it? So the MAP would see the 0.5 bar on both turbo's
current vehicles...
1979 Corolla SR5
1996 S14 200sx
1979 Corolla SR5
1996 S14 200sx
Makes sense colder air=more dens air=need more fuelGary57 wrote:Yes BUT they will produce different power because of the temp of the air.
In this case, because you are running the MAP sensor and (I pressume) MAT sensor (temp sensor), any small changes will mean your map is off. The advantage of running a Z32 AFM (or any AFM/MAF capable of measuring your power) is that you can make small changes without the need for a re-map (such as running a bigger turbo at the same boost, changing exhaust system, changing intercooler and piping, etc).
