mmm I had similar issues... p-ed me off and I stuck the old ecu back... at least that was working... at one stage the car started with the ecu and bikirom but was in limp mode... never got it working... will try this once more when it is running but if it fails again I am really buying nistune... seems like there are no real problems with it at least...
(praying software works...)
1. Download and install the newest Bikisoft.
http://bikirom.com/Software.php
2. Install the bikirom into your ECU.
http://forum.bikirom.com/viewforum.php? ... 9b79f6806d
3. Plug the bikirom into your computer. You should be prompted for new hardware install. Direct the installer to the USB Drivers folder under the directory where the bikisoft was installed.
4. Make sure the cars ignition is set to on and start the Bikisoft program. Make sure you are WORKING OFFLINE.
5. Do a firmware update right away. It might take a while and you might not even see any progress bars for a bit. But let it work and it should finish. If it takes more than....5 minutes you might have a problem.
6. After the firmware is done(it will let you know in the lower left) load up the correct bas file cooresponding to your ECU. This is very important, make sure you use the correct base file.
7. Now go to adjust-> data streams and select all of the variables to "stream" except the last 3(which arent needed).
8. Make sure you UPLOAD your new settings and map to the bikirom. Once that is done reset the ecu(turn the key off and then back on).
9. Now press F8 or select work online. You should see the TPS, water, ign, and all of the other consult features function. Press the gas pedal to make sure it is reading.
10. Have fun tuning!
- is said to work this way... mmmm
