For sale: 2 x T28 Turbo + split down pipe.
Different strokes, I would far rather have nice low and mid range because this is where I spend most of my time when driving. I floor my car maybe once a week but drive it everyday, everyday drivability is farmore important to meI would sacrifice low end torque for mid to top any day
More overlap more reversion but Mid-range should be greatly improved. I love the DE cam It made a huge dif on my rideI really don't mean to sound like a broken record. but anyway, if this turbo is alot like the stock CA, what would happen if you introduced the DE cam into it. So this T28 + DE cam = ...
The R@D I have done on the GT-R turbo shows there are 6 Different types might be more RB will know.The specs PFB posted show the Compressor A/R to 0.60, but the description for these turbos show that it is 0.42?? Am I missing something here?
Most are just slight changes from model to model like the R32 RB26DETT to the R33 RB26DETT and so on the Comp housing Doesn’t play a a large role in the Flow rate.
- Trance101
- 0.9 Bar Boost
- Real Name: Ryan
Here are the specs I've found for this turbo that seem right:
Garrett T28 TE2701 turbine
RB26DETT Turbo
Identification number: 14411-05U20
T28
T3 Compressor Housing AR42
Wheel T3 Trim 50
Inducer = 42.51
Exducer = 60.1
Turbine
Housing AR 48
Wheel T25 Trim 62
Inducer 53.8mm
Exducer 41.7mm
Bearing = 273 Metal Journal bearing
RB26DETT Turbo
T28
Wheel T3 Trim 50
Inducer = 42.51
Exducer = 60.1
Turbine
Housing AR 48
Wheel T25 Trim 62
Inducer 53.8mm
Exducer 41.7mm
