Man, that FJ20 is a mean little basted, only 140kw odd stock but its crank could hold 600hp+! loads of guys used them in their light weight racersThe S12 chassis in Japan was badged as both a Silvia and a Gazelle. The Gazelle was produced so that Nissan's different dealership networks in Japan could all carry the Silvia. There are minor cosmetic differences. Both the S110 and S12 Silvias have a Gazelle counterpart. The S12 Silvia in Japan was available in a fastback as a basic model only, but the S12 Gazelle in Japan was strictly a fastback, available in regular, RS and RS-X variants, as was the Silvia notchback. The RS was equipped with the 2.0L DOHC "FJ" engine(FJ20E), while the RS-X was equipped with the same engine in a turbocharged version (FJ20ET). In 1987 Nissan discontinued to put in the FJ Series engine and installed the updated version of the older CA, with dual cams and a bigger turbocharger -- the CA18DET.
160kw at stock boost? either your dyno was jippo'd or your car wasnt running stock boost (maybe not to your knowlege), 35kw/46hp is impossible from an exhaust and filter only to an other wise untouched CA18DET or SR20... I have probably dyno'd 150+ CA18 and SR20's on our dynojet 248HS I used in the US, a SR or CA swapped S13 used to pick up 30 to 35hp max! out of exhaust and intake only, and that was with top end off shelf systems and intakes.
Ohh and if you think bang for buck is RB
